Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Locking mechanism came off my impact
I pulled the locking mechanism on my impact to get the bit out and the bit didn't want to come out so i pulled the bit and the mechanism at the same time and the pulled the locking mechanism off. To little steel balls and couple little rings along with a spring fell out. any idea what i did and how to fix it?
  • 2,176 Answers
You pulled the retaining ring off the end of the chuck shaft. Not to worry go to Makitatools.com and type in your model number and it will take you to a page where you can download a schematic on the repair of this.
Posted on Jun 21, 2009
How do you Insert a Ryobi One+ impact driver drill bit?
don't think there is much to it. See page 4 in this manual
http://www.ryobi.com.au/Ryobi/files/e0/e029b72d-32ec-4e92-a555-2a3caac4fa92.pdf
Pull the chuck out to unlock it and push the drill bit and chut back in to lock it.
Hope this helps.
Apr 28, 2014 | Ryobi Impact Driver Kit: 18-Volt ONE...
Air opertes but locks up under load
Sounds like you might have a problem with the hammer (clutch) mechanism, these types of impacts are direct drive there a re no gears, so the hammer (clutch) mechanism must have the ability to splip after impacting to allow the air motor to turn. Disassemble and look for broken hammer pins, hammer dogs.
If you need a parts list you can go to CP.com, powertoolrepairohio.com or ereplacementparts.com
Feb 01, 2014 | Chicago Pneumatic 1/2" Air Impact Wrench
Dewalt dcf885 will not lock the bits in
It could be the little spring at the back of the chuck sleve is broken ot one of the locking balls is missing.
Apr 01, 2013 | Dewalt DCF885 20V Max* Lithium Ion 1/4"...
Bit falls out of impact driver
There is a small spring at the back of the sleve which snaps. Try replacing it. it is only cheap.
Feb 02, 2013 | Dewalt DCF885C2 20-Volt MAX Lithium Ion...
I have a BTD141 and it has been driving in screws perfectly. Am on 2nd battery charge. It has lost the hammer/impact feature. It only occurs if you push so hard you bend the screw. No long impacts. I...
could be the anvil stuck on the hammer mechanism, try locking a bit in a vise and impacting. also could be wear on the edges allowing the 2 to slide past each other
Jan 11, 2011 | Makita 18 Volt Hammer Drill Impact Driver...
I received a Craftsman 12V Impact Driver for Christmas. Any quick-connect bit that I insert into the driver seems to be loose. Is this normal? Am I doing something wrong?
do your bits have a recess cut into them to lock into the mechanism?? and yes there is some "play" in the bits as long as it doesn't get worse I would think that it is normal
Jan 08, 2011 | Craftsman Drills
Dirver won't impact working like drill...
Depends how old the tool is and how hardly/frequently it was used. It has mechanical impact mechanism, not a electro-pneumatic. And mechanical one can be worn off after certain period of use. If your drill is new, issue can be either "wrong tool" - then return it to the shop, or you have not turned hammering on - check user manual. Impact effect will occur only if you put a pressure on the drill bit. Juraj
Oct 11, 2010 | Ryobi Drills
Someone stuck a conventional driver bit into the impact driver and it is stuck tight.
VERY GENTLY. . . . use a flat tip screw driver to try to push the collar forward so that it will release the bit. You may need to gently hold the handle of the impacter in a table vice or something like that to steady the tool, then push forward on the collar with a screwdriver and use a pair of pliers to pull outward on the bit at the same time.
Or instead of a screwdriver try vicegrips that are adjusted loose enough to just lock but not squeeze when closed. Pliers that grip too tightly may bend the collar and keep it from being able to slide forward to release bits.
Dec 03, 2009 | Ryobi 18v Variable Speed Impact Driver...
Cannot remove drill bit from self locking chock
If you are having trouble turning the chuck to remove the drill bit just wrap a cloth around it a couple of times and use a pair of adjustable channel lock pliers to give yourself a mechanical advantage. If you have loosened the chuck but can't remove the bit just clamp onto the bit with a pair of vise grips and tap them a few times with a hammer while a friend holds the drill for you.
Nov 09, 2009 | Drills
How do you change the drill bit for a Ryobi?
My husband explained this, via phone ..... made it simple....... grab the silver ring area beneath the black top area where the drill bit is located. Hold the silver area firmly, while you twist the black top. You will see the release, then remove drill bit. Laymen's terms, but it worked!!
Mar 16, 2009 | Ryobi 18v Variable Speed Impact Driver...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
159 people viewed this question
Top Makita Drills Experts
John Trevino
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
