No screws in 2011 pat , it uses 2 reuseble plastic push rivits to hold on tail lights. be carefull in removing, best to go and buy 4 new plastic rivit type fasteners before attempting removal.
remove by using pliers to grab sides of top and lightly pull and twist to remove
Lamp, bulb, supply and ground obviously ok as the hazards work - I suspect the hazard switch might be faulty or something like a dodgy multiway connector onto the switch...
Peel back the trunk lining to reveal three wing nuts. Remove wing nuts to pull lens cap away from car. To remove bulb socket push on the rectangular button (the release) while pushing on the end of the socket to unlock and spin counter clockwise to release. pull out old bulb and reinstall lens cap.
Turn the engine off and open the hood. Pry up
the two fasteners from the radiator air baffle with a flat head
screwdriver. Move the baffle to the side to access the top of the
headlight case.
Step 2
Pull up the two metal rods behind the headlight case. These
secure the case to the car. You may
need your pliers to pull them up.
Step 3
Gently pull the headlight case out to access its rear. On the
rear, you will find several black dust covers. Twist off the dust cover
closest to the fender (the outward dust cover) to access the turn
signal bulb.
Step 4
Turn the bulb module counterclockwise to release it. Unplug
the electrical connector from the bulb module. Connect the new bulb to
the electrical connector (don't touch the glass with your hands; hold it
by the plastic piece). Insert the bulb module in the turn signal
housing, turn it clockwise and screw the dust cover back on.
Step 5
Insert the headlight case in the mount. Push the pins back
down to secure it. Position the radiator baffle in its place and insert
the fasteners.
Rear Turn Signal Bulbs
Step 1
Open the trunk. Remove the net from the
side mounted wing nut (on the side with the faulty turn signal). Twist
the wing nuts (there are two per side) counterclockwise to remove them.
Step 2
Peel the carpet layer back to access the rear signal lamp
wing nuts. Twist these wing nuts (two per side) counterclockwise to
remove them and release the rear signal.
Step 3
Carefully pull the rear signal assembly away from the Impala.
The rear turn signal is the inner bulb (closest to the trunk). Press
the tab on the bulb module and turn it counterclockwise to release it
from the rear signal assembly.
Step 4
Pull the old bulb straight off the module (don't twist).
Insert the new bulb in the module. Depress the tab on the connection and
insert the module back in the assembly. Twist it clockwise.
Step 5
Insert the rear signal assembly. Re-attach the assembly's
wing nuts and push the carpet layer back in place. Tighten the other two
wing nuts to secure the carpet layer and reconnect the cargo net
The turn signals flash depends on each and every bulb working correctly. When one bulb fails, you will notice a change in the flash frequency, as you describe.
Replace or repair the bulb that is not working, and you should be good to go.
The turn signal switches are known to go bad, try to use the turn signal switch and jiggle the lever after clicking to the left turn. Replace signal switch assembly.
