I have a 2002 Ford Expedition 4.6L. I am attempting to add fren 134 to my system. I have a recovery unit and prfessional guages. I simply am not able to find the low side charging port on this vehicle. I have looked high and low. No low side port visible. Does any one have a handle on what the answer might be? Thanks a bunch for helping out.
  • 3,600 Answers
It should be on the accumalator or on the compressor hose they have them in different places and in three different places, look for the low side switch and you could vav it down there and charge itthere if you use a paper clip to keep the compressor going.
Posted on Jun 21, 2009
Where is the fuse for the air conditioner on a 2002 ford explorer?
Here you go.............Repair Guides Explorer Sport 2002 Fuse And Relay Information AutoZone...
If compressor not engaging, could be low on R-134 from a leak in the system. There is a low pressure switch in the system that prevents it from coming on if it's low on R-134.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/michael_2496c4f07ad24453
Aug 30, 2014 | 2002 Ford Explorer Sport Trac
My 2002 Ford Expedition has a stuck a.c., it doesn't heat up. I replaced the Temperature control unit and the motor for my heater actuator, still no heat? Please help?
Its a faulty heater control valve that is located in between the engine and the heater core or just before the firewall.
Jan 31, 2012 | 2002 Ford Expedition
Where to self charge a/c unit?
Before attempting this make SURE your vehicle is running R-134 coolant. If it is running R-12, you will have to have this done by a professional. DO NOT attempt to mix R-12 and R-134 coolants, as this mix will become volatile and could possibly explode and cause massive system damage. You can find out what type you are running by looking for a ( usually yellow) decal on top of the A/C compressor or on top of the air accumulator ( the silver soda can looking thing.) Once you confirm you are running R-134, trace your A/C lines back from the compressor until you find two nipples, one large and one small. The large one is your "low side." This is where you will attach the recharge kit to service your system. The recharge kits are designed to only fit on the low side, so you won't have to worry much about confusing the two. Hope this helps you out. Have a good day!
Jun 07, 2011 | 2001 Ford Escort ZX2
2002 Ford Expedition, the rear A/C needs a recharge, where do I find the connection?
it runs on the the same system as the front A/C (they utilize the same A/C compressor. Are you getting any thumping or clicking noises form the rear A/C unit?? Is the rear A/C blowing hot??
Aug 12, 2010 | 2002 Ford Expedition
How do I add freon to a 2002 Ford Taurus? The
YOU NEED THE R 134 CHARGE HOSE KIT.YOUR CAR DONT HAVE R - 12 FREON.THEY STOP USING FREON BACK MID 90S ALL CAR NOW HAS R-134 REFRIGERANT.
May 31, 2010 | 2002 Ford Explorer
Reseting the keyless entry on a 2000 ford expedition
unfortunately, ford does not allow this. Instead the system can only be programmed to add up to 8 different codes. The only alternative is to replace the security control unit.
May 12, 2010 | 2000 Ford Expedition
2002 ford expedition air conditioner needs R 134 refrigerant. I cant seem to locate the service port.
The low pressure valve on the 02 expedition is located on the accumulator on the passenger side fire wall. The accumulator is underneath the battery relay and a grouping of wires. Had to squeeze hand underneath a heater2_bing.gif hose and an a/c line to remove cap and hook up hose. Nothing has to be removed to locate the valve just a little touchy feely. Valve faces a 45 forward toward the engine.
Jul 06, 2009 | 2002 Ford Expedition
Can find where to hook up the hose to add r 134 to my ac unit on a 2002 ford focus
find the a compressor has two lines coming out of it ,follow the large line/hose untill u come to the low side service port this is the one the small line/hose has a large service port used only in diagnoising the charge hose will only hook up on the low side
Jun 30, 2009 | 2002 Ford SVT Focus
Delete emachinesSystems Recovery and Angels Systems software
You should be able to simply uninstall it in the control panel add and remove programs
Start > Control Panel > Add And Remove > locate the entry relating to the application you wish to install.
Apr 16, 2009 | E-Machines (T2824) PC Desktop
2002 Ford Expedition Climate Control System
mode door actuator , it's a electrically controlled motor under the dash on the heater / A/C unit . Videos on youtube showing how to replace them .
Sep 23, 2017 | 2002 Ford Expedition
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
