Question about Weather King Heating & Cooling
How to tell the size of my ac unit?\
How to tell the size of my ac unit? no paper work, just suction pipe size,Do i check the amps OF THE LOAD on start up.
Its a model 10AJA6001AH
  • 38 Answers
Thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Posted on Jun 21, 2009
1.ton ac capillary pipe size and length I want to know. B coz suction line cooling level is very low gass psi 75
I'm guessing you should have 3/8 & 5/8 copper on that unit with a maximum of 50 feet. I doubt the line set size is affecting your pressures that significantly, you likely have a leak.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
May 05, 2017 | Heating & Cooling
I have a 2001 Tahoe & i cant find the four season suction ac line . I have rear ac but the one they show for my truck isnt right...
******* A/C pipeline is bigger than the discharge pipeline. I believe your ******* pipe size should be 1/2 inch and your discharge 3/8"
Hope this was helpful
Regards
Jun 09, 2016 | Miscellaneous
Lg 1.5 tr split ac capilary replaced.size 5.0 ,length 1 1/2 ft. gas charging done.ac running for 20 mints.after 10.7 amps incressing and of the compressor over heat.i will replaced 50+4 running...
The best practice when replacing a cap tube is to replace it with the identical size and length of the old cap tube. Also, you must run it in the same way, if the cap tube was soldered to the suction line in any area then the replacement should also be soldered to the suction line. The old cap tube should have been stretched out, measured and gauged with a cap tube gauge. If you just went by load, it appears your cap tube is the wrong size, should be a #4 or .064ID and not a #5 .028ID. This is just based on some cap tube sizing charts I looked at assuming you have a single cap tube and not a multi circuit evap. Other than the cap tube the symptoms point to a system that was overcharged, dirty condenser, condenser fan motor not running. If you have a way to check suction and discharge pressures this will be the best way to see what is going on.
May 10, 2014 | Heating & Cooling
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to fix this error in printer hp p2055dn ''manual feed press ok for available media into tray 1
Aug 01, 2012 | HP LaserJet P2055d Printer
Keeps telling me to load correct paper into tray 2 (says unexpected paper size 41.3)
Hello pls match the paper size in tray manually & printer setup . go to page setup & match the size as well as set manualy in tray2 & same in printer driver page setting your problem will be resolved 100%.
Sep 20, 2011 | HP LaserJet 3015 All-In-One Printer
What is gase and liquied pipe size of 2 ton split ac mitsubishi
Refrigerant R410A. and pipe sizes will be Suction pipe 5/8" and Liquid line will be 1/2"
Helpful?
Jan 24, 2011 | Heating & Cooling
Two lennox heatpump 71/2 tons
check the true psi with the line psi to see if same if psi is good in cooling 225 hi and 70 low on 80'day then compressor is fine and i would start checking for temp difference on the reversing valve sometimes this will cause high suction or high discharge psi shift it manually with by energising it be cooling or heating then pull wire and see how it shifts if shifts good then txv on out door unit could be bad what is the psi in heating on the discharge line going to the indoor unit? most prv's are set at about 350 psi r22 as for suction line size its only hot gas in hp mode os no problem their shows in cooling mode as low suction psi ..hope this helps some also make sure indoor coil is clean!....thanks & rate me
Apr 19, 2009 | Ruud UBHC Air Conditioner
Oil trap for 2 ton split unit
Pipe size is okay, not that I know any better than the manufacturer, but I would recommend at least two and possibly even three oil traps in the vapor line on the way back up.
Jun 14, 2008 | Heating & Cooling
Samsung split system air conditioner model as24bpa
Suction-5/8"
Liq. line-1/4"
Max pipe length-50'
Max vertical hight bet. accu and fcu-25'
Jan 06, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
2,451 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
