Question about De Dietrich 22 in. DTI305W Electric Cooktop
Element on cooktop will not switch off
To extinguish it is necessary to switch everything off at the main power switch
    Problem Solver:
  • 10 Answers
Probably the contacts at the switch are welded together. I suggest removing the switch and if found to be so, separate and clean with a small bit of fine sandpaper.
Posted on Jun 21, 2009
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
GE F105 error
According the service guide, an F105 error is "Zero cross failure"
Correction action is:
(1) Recycle power to the cooktop (i.e. turn breaker off and on)
(2) If fault persists, test the line voltage supplied to the cooktop at the wall outlet. Voltage should read from 175VAC to 265VAC. If it does not, there is a problem with the power being supplied to the cooktop.
(3) If fault persists, replace power board
(4)If fault persists, replace main (Logic) board and recalibrate elements.
Mar 31, 2013 | GE 30 in. Profile JP939 Electric Cooktop
Press power on switch and blows main fuse box
Possible that the main heating element is faulty. It is possible that the wires have shorted or due to insects if there was failure of the insulation of the wires leading to shorting of the lead lines.
Disconnect the main lines and use a multimeter to check and confirm the short of the heating element or wires.
Take all precaution for safety in testing live circuit.
Aug 18, 2011 | Neff T1323 Electric Cooktop
Error 108
According the service guide, an F108 error is Line Monitor Failure
(4) If fault persist, replace logic (main) board
Search for my solution for replacing an element (JP939/JP969) for the basics to open up the unit.
Apr 09, 2011 | GE 30 in. Profile JP939 Electric Cooktop
We have a WLP83800 Whirlpool ceramic-top range. The indicator light for the left front element now stays on even with the control for that element in the off position. As well, the element doesn't...
We are very sorry to hear this Jedpaquette. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to Whirlpool_Digital@Whirlpool.com.
May 09, 2017 | Whirlpool GJC3634HQ Electric Cooktop
One of the burners on my kitchenaid cooktop will not heat up. What do you think the problem is? Is this something that can be easily repaired?
If it is not a glass top stove, with the power OFF, and cold, pull out a working element of the same diameter and install it where the non-working element was. Try it now. If it works, replace the heating element. If it does not, check for voltage at the element connector. CAREFULLY. Worst case is that the switch requires replacing.
Dec 17, 2009 | KitchenAid 32 in. KECD805 Electric Cooktop
Rear eye want come on
sounds as if you have a wiring issue, somehow power is backfeeding into the other switch. aliitle too late but was the switch an exact match or was it a new substituted aprt, its possible that the manufactue either sent wrong part , or the new switch altough appears the same ,,wire terminals were in different locations
Nov 10, 2008 | Frigidaire 26" Built-In Electric Cooktop -...
Maytag, precision control 500 [canada]
the infamous "custom control kit" its an electronic board that only control that one precision temp burner all other elements ar regular switches, if thats the one where the sound os coming form replace the control. .nothing else to do
Dec 26, 2007 | Maytag MEC5430BDS Electric Cooktop
Open Questions:
De Dietrich 22 in. DTI305W Electric Cooktop Logo
184 people viewed this question
Top De Dietrich Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a De Dietrich Cooktop Expert? Answer questions, earn points and help others
