Question about Sony VAIO VGN-FS742/W Notebook
USB ports won't work after hard drive format
Computer was non functioning, so I formatted and reinstalled Windows XP Home, Have Motherboard MS-6741, couldn't get onboard video to work so installed another video card, but the usb ports will not work also. Do you think it's a motherboard malfunction, or is there something I can try for the USB?
    President:
  • 3,278 Answers
I suspect that your onboard video is conflicting with the video card. Remove the card to see if the USB problem is resolved. If resolved, reinsert the video card and go to Control Panel - System - Device Manager and disable onboard video.
Posted on Jun 21, 2009
  • 121 Answers
Hi
well u can try installing an USB PCI card .You must also check the usb status through device manager.For more technical help you can visit at------http://robs-tech.blogspot.com/2009/06/get-technical-support-related-to.html
Drive windows format
ignore the format thing, totally.
its MS way of telling you , its seems corrupted.
what system? PC, dvr, MAC, laptop.
what OS, windozs what,? xp,w7.w8?
the FreeAgent is and external HDD.
1: is the power pack plugged in?
2:is the led indicator dead on HDD.
3: did you try all USB ports.
4: did you try it on another system.? and USB port?
5: did you look in disk manager to see if it shows up, say DISK2?
6: did you ever drop it?
Oct 05, 2013 | Seagate 500GB FreeAgent GoFlex Hard Drive
Windows 7 won't recognise buffalo hd-ce1.otu2
you might back up your data to another drive if possible
then format your buffalo drive then transfer it back
i have had similiar issues with xp and w7 using usb drives and have found that i have to designate certain usb drives to the computer running windows 7 and same running xp
if i try to use the one designated to windows 7 in my xp get this drive is not formatted do you want to format
although these drives are not buffalo just usb data drives but of large capacity 128GB
make sure the lead/s that attach to your hard drive are securely seated
if your computer came with a motherboard disc the drivers could be on it
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
hope this helps
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Feb 13, 2012 | Buffalo Technology Computers & Internet
Will i loose pictures & other files if i format my pc
Yes you will lose all files when you format.
If you want to save your files but cannot open Windows on your computer then remove the hard drive from your computer and connect this hard drive into an USB hard drive adapter. Plug this adapter and hard drive into the USB port of a working computer, this computer will see this as an external storage device, you can then open the folders on this drive and copy/backup the various folders and files.
After you have copied/backup your files, you can install the hard drive back into your computer to format and reinstall Windows.
Feb 06, 2012 | Lenovo Computers & Internet
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
How to format usb that says it has 8mb capacity.
To Format Any Flash (USB) Drive
WARNING: This will permanently remove ALL data from your flash drive.
1) Insert the flash drive into a working usb port on your Windows PC.
2) Open "My Computer" in Windows XP or eariler OR "Computer" in Windows Vista/7
3) Right click on the Flash Drive (Usually labeled "Removable Disk")
4) Click "Format..."
5) Ensure that file system is "FAT32", Volume label is a name of your choosing, and that "Quick Format" is unchecked
6) Click "Start"
7) Windows will warn you that all data is about to be deleted. Click OK.
8) Once the format is complete, Windows will produce a pop-up window telling you so.
You now have a blank flash drive.
Apr 12, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My computer won't discover my brand new 250 gb Seagate hard drive. It's connected by a USB port in a HP compaq computer running windows xp version 2002. It didn`t come with any software and says it`s plug...
It is possible the usb port is not giving enough power for the device, theres a cable the allows you to connect the device to 2 usb ports to get more juice, maybe that could help.
Mar 21, 2011 | Seagate 320 GB USB 2.0 Portable External...
I want to format my pc and fix xp service pack 2.how can i will be able to do this???
Hi, before you format your hard disk, make sure you have saved all important files that you like to keep on an external drive, for example a USB Stick. Formatting your hard disk will destroy all data.
If you want to format and reinstall Windows XP do the following:
Insert your Windows XP CD. Restart your computer. Your computer should then automatically start from the CD and show the Windows XP Setup.
In Windows Setup you can choose the partition on which you want to install Windows. There you can also format the partition, before installation. To do this, just follow the directions that are shown.
Jul 12, 2010 | Computers & Internet
Verbatim portable hard drive not recognized by XP - works in 2000
Restart XP and connect e/hd and it should pick it up. Some systems are plain lazy after a while, so manually install it.
Aug 27, 2009 | Verbatim SmartDisk Firelite Portable USB...
Windows XP wont install USB card readers
Did not reinstall the needed drivers. Download drivers from manufacturer support and install them.
Maybe just maybe you can use device manager to install the drivers by searching the web for them. Only take a minute to make the attempt.
Mar 05, 2017 | SanDisk ImageMate 12-in-1 USB 2.0 Card...
Unable to recognize usb to install drivers after format
maybe you didn't install windows xp professional properly
Dec 22, 2008 | Acer Aspire One PC Notebook
Sony VAIO VGN-FS742/W Notebook Logo
133 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
