Question about Whirlpool RF378 Electric Kitchen Range
When I turn my oven on it will only go to door
I have a self clean stove and it will clean my oven but it will not turn my
oven temp on. My stove top works fine
The problem was the oven microswitch, it needed to be replaced. Now my stove and oven works fine
Posted on Jun 25, 2009
How do I turn the temp down after oven has been on for a while. 'Loc on' message is showing and will not allow me to turn oven on.
Can you provide some additional details to help me help you? What kind of stove (make/model) and does it have any kind of self clean mode?
Without knowing the above details generally speaking of the oven is already preheated, to change the temperature you would hit the bake/preheat button to then adjust temp up or down with a digital stove. The dial stove from is self explainatory!
That loc on message may be because you have a stove lock lever or feature that prevents the stove from being opened when enabled, or when the stove is self cleaning. This may prohibit the adjust meant of temperature when the lock is on, or the stove is running through the self clean..
Again all just a general thought without knowing the above information... if you can post back or let me know is this was helpful in anyway to you! Thanks!!
Feb 13, 2017 | Ovens
Self cleaning oven
Pheo,
Turn Breaker/Fuse for the stove, your electrical panel, “OFF” and then “ON”, wait 20 - 30 seconds and the door should unlock.
It may be that the temp sensor is going out and you'll need to have that looked at soon.
Bill
Nov 21, 2007 | Whirlpool GBD307PDS Electric Double Oven
I have a self-cleaning older Frigidaire oven RE36BNL*2 and have had several power interuptions. I went to use the oven and the timer and oven controls won't work. There is an OFF displayed and it...
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
How do I get self clean to work on older fridgidare stove
Move the safety lock/lever at the top of the oven door to the right and press the self clean button on the oven control panel, it is an automatic cycle so it will lock the door from opening and then will proceed with the auto clean cycle. Good luck !
Jan 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Touch pad will not unlock after running self clean cycle,
ran the SCC and the oven door unlocked when completed but the touchpad did not. Can;t use over at all, top of stove works fine. None of the bottons for the oven works. still says self clean completed, will not go away, can't use oven at all.
Dec 14, 2009 | KitchenAid KESC307 Electric Kitchen Range
How do you self clean the oven?
look for the oven door locking lever ,on front,just below stove top & above top edge of oven door.pull lever out to lock door;dial up 'self clean'
Sep 25, 2009 | Ovens
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
Jul 07, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven went in self cleaning mode and shut off door unlocked f90 error code will not bake
During the cleaning cycle, there was a temp sensor malfunction that may have damaged the temp sensor. this is a common occurrence with this model. this is refereed to as a runaway temperature code. the sensor lost control of the cleaning cycle and it got to hot. the temp sensor is fried and it will need to be replaced.
May 22, 2009 | Stoves Ovens
Old Amana - no manual; can't operate self clean feature
Can you locate the model number on the oven? Also any particular name of the stove? The manufactured year. These should all be available on a stainless steel or aluminum attached plate , probably on the back of the stove or inside the door.
I wouldn't try using the self cleaning feature until we get some advice. it could lock up on you and not UNLOCK. Normally self cleaning takes place at 600 or more degrees .
I'm sure others still have the same stove., I will see what I can find for you.
Aug 21, 2008 | Amana AEW4530DDS Electric Single Oven
Whirlpool RF378 Electric Kitchen Range Logo
194 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
