Question about KitchenAid KGYS850LT Gas Dryer
Kitchenaid gas dryer had a pair of gym shoes in it and one of them got jammed and stopped the whole thing. Now it won't do anything when the start button is pushed. Is there a reset in this unit?
    Problem Solver:
  • 18 Answers
If it jammed then it might have damaged the motor. There is no reset other than a motor overload protector that cutspower to the motor if it gets too hot. When the motor cools down if might restart
Posted on Jun 21, 2009
Where can I buy rock climbing shoes?
Its pretty simple to buy a rock climbing shoe from a physical shop or brand shop also you can place an order from your home on their online shop .
But before you go for a purchase make sure about the primary considerations:
Shoe type: It depends on your experience and expertise for which type of shoe you should choose for climbing .
There are There are three types of rock climbing shoe based on the shape:
1) Neutral2) Moderate3) Aggressive
Features: Before you take any decision on purchasing climbing shoe , check out features as what has been provided in it.like laces, straps,inner,outer, linings,last and rubber affect the performance of a shoe.
Size fitting: Climbing shoe need to be fit snug to hold on with full strength.
but It's a common mistake for first-timers to buy climbing shoes that are way too tight. Old-school wisdom and advice was to cram your little piggies into the smallest pair possible in an effort to help you climb better.
Hope you find it helpful and appropriate.
Apr 04, 2018 | Rock & Ice Climbing
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Kitchenaid gas dryer won't ignite and heat. Everything else seems to work fine -- drum rotates, timer works, just no heat. Model# KGYL517BWH1.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | KitchenAid Dryers
A few days ago our tumble dryer begun to make a clunky noise as it was spinning. The noise is like a shoe is being dried inside, banging around the drum. Now the machine won't work at all, the...
that could be anything you just have to unplug the dryer and get in there and see what happened,the belt pulley could have failed and jamming up the belt,first off does the dryer start?if so and the drum isn't spinning then the belt could be broke but this says it's a g.e. dryer so this has a safety switch in it that won't let the dryer run if the belt breaks,also g.e. has a rear bearing that fails,did you hear any sounds before like metal on metal,this could be alot of things,there's a front bulkhead with glides on it,i've seen the drum cut through the front of the dryer before, if you write back send the brand name and model number and anything else you heard before or take it apart and see what's up.if the dryer has alot going on with it don't buy another g.e. dryer get a whirlpool.
Dec 27, 2017 | General Dryers
Kitchen aid gas range igniters won't stop
Jammed and broken ignight switch or the spark generator transformer has a short circuit
Jul 13, 2011 | KitchenAid KGSK901SSS Gas Range
Which gym shoe should I buy? I figured someone here may know about gym shoes? I walk and do a tiny amount of jogging. I just want a shoe that I put on and say wow that's great.
If you plan on running, find a running specialty store. They'll let you try on different pairs, jog around and see how it feels. If the store is a decent one, the salespeople often can look at your gait and recommend something to provide the right support in the right place.
Oct 27, 2010 | Clothing Accessories
Dryer will not restart after tennis shoe getting stuck in it
Make sure door is closed firmly. Try to Press and hold the START Button for 4-5 Seconds.
Good Luck and have a nice day.
Jun 29, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
I have a Neptune model MDE9700AYW dryer that wont start
Check to see if the little tab in the door jam, which causes the dryer to turn off, is broken or bent. If its bent you may just need to bend it back.
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer spins but does not get hot
The problem could be a faulty component such as the timer, heating glow bar, gas coils, safety or operating thermostats. First thing to do is to check the venting to make sure it is not plugged. I cover that more in detail if you wanna check it out.
http://tclaundryrepair.com/dryer
Feb 26, 2009 | KitchenAid Dryers
My dryer drum is no longer turning when I press start.
When you turn it on, can your still hear the motor running but the drum doesn't spin? If so, yes, the belt could have broken or slipped off the pulley.
With my dryer, putting in a pair of shoes often makes it turn off. I hear it tumble for a while and then and then I hear a squeal and then the dryer turns off.
I have seen a device that can be put inside a dryer and adjusted to fit tight between the diameter of the drum and will allow you to put shoes on it. This solves the CLUMP - CLUMP - CLUMP issue.
If you don't hear the motor, its possible there is a blown fuse. have you checked your breaker panel too?
Good luck,
- Jim
Jul 15, 2008 | Danby DCD5505W Electric Dryer
KitchenAid KGYS850LT Gas Dryer Logo
85 people viewed this question
Top KitchenAid Dryers Experts
Tim Whalen
Oloyede Monsuru
Virgil Watts
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
