Question about Vivitar V-2200GX Tripod
Where can I find a quick release for a pro line 100?
How do I connect the air hose to the compressor and the air gun?
Yes you need a quick release couple r kit male/female kit prob 3/8
also get a roll of Teflon tape wrap the male ends in it before you add the new fittings also you might to buy a "swivel" quick release and use it on the end that goes to the gun this helps stop the hose or line from bindind up on you and they don't cost to much oh ya keep a dab of oil on the ball bearings...
Sep 14, 2014 | US Freight Neiko Pro 2.0mm HVLP Gravity...
I have a kalimar tripod pro-tech v-40 and I lost the quick release plate that connects to the camera. Where can I buy this part?
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
Aug 19, 2010 | Photography
Lost the quick release head for this tripod
Jul 27, 2010 | Quantaray QSX-DigiPro 100 Tripod
Cant get the fuel quick conncect to release.
Are you using the proper quick disconnect tool and size. If not, go to autoparts store and purchase a cheap set. Choose the right tubing size one and slip it right around the line. Then, push it foward into the flare of the connector, and just pull it apart..... or you have what's called a hair pin type nylon connector. I believe that you just pull out on the tab and it will relese the line. If you break it, I think you can get more from autoparts store. Good luck!42301612
May 31, 2010 | 1998 Ford F150 Regular Cab
Where can i buy a quick release block for my miranda pro-video 1 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen. Because your tripod is not supported by the manufacturer; parts lists and pars are not available, you should measure the opening and see what other brand quick releases will work paying attention to the shape and locking mechanism. Otherwise just get another tripod.
Apr 21, 2010 | Photography
Can not get quick disconnect line to release out of the transmission on 1997 ford ranger
The quick conect lines can sometime be hard to get the springs to release. First of all you need to make sure you have the proper tool and size that will fit inside of the connection. Then sometimes you might have to slightly take a small hammer and lightly tap the release tool up into the quick connect to release the spring. This usually works for me. But you must have the proper tool to do this.
Mar 28, 2010 | 1997 Ford Ranger SuperCab
Who do I contact to get repair of quick release's on 519 tripod
Jan 18, 2010 | Bogen Communication Bogen / Manfrotto 519...
Need a quick release plate for Dynex tripod 60
Quick release plates can be purchased on amazon, here: Amazon com Dynex tripod quick release plate. Take a look. Wish you ebst of luck.
Thomas
Nov 03, 2008 | Dynex 60" Universal Tripod
Vivitar V-2200GX Tripod Logo
43 people viewed this question
Top Vivitar Photography Experts
JP Services
JP Services
JOHN TOPLISS
Jax Planet
Jax Planet
Are you a Vivitar Photography Expert? Answer questions, earn points and help others
