Question about Kodak EASYSHARE V1253 Digital Camera
Same lens/power off problem
This happened to my original after a month and I was sent a refurbished. Now it happened to the refurbished. After 2-3 calls to Kodak and talking to the "supervisor" who sounded like the same person on the other side of the world, they offered me 25 dollars off my repair. You have to be kidding me. Warranty aside(no longer under warranty) I should not have to pay for it when I'm onm my 3rd Kodak V1253 in 15 months!!!!!!!
  • 3 Answers
Frist tell me what the problem is, be spacific and i will try to help you fix your camera.
Posted on Jun 21, 2009
  • dalitso Jun 21, 2009
    frist tell me what the problem is, be spacific and i will try to help you fix your camera.
My nikkon coolpix is a month new and almost only 3 weeks used..my uncle bought it in states...when i am taking pictures i zoom it and a message "LENS ERROR " appear on the screen and because i...
1.Check if something block it (maybe sand or smt like that
2. Never pushed lens manualy (you may broke it completly)
3.Just try to shake or slap it jently while open or close it.
Jun 07, 2011 | Nikon Coolpix S3000 Digital Camera
Auto Focus not working for Canon EFS 18-55mm lens
This usually happens when the contacts between the lens and the camera are dirty. Try taking the lens off and cleaning carefully the metal contacts on the camera and the lens. If that does not solve the problem, you can get a warranty repair or replacement since that camera should still be under the original 12 month warranty.
Jul 20, 2010 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
The lens has stuck in the closed position This happened 12 months ago as as repaired under warranty. the camera has not been used for a few months but has no stuck. thsi is a silver samsung l820 digital
Since you were not as clear as you could have been, my expertise is limited. When I had a camera like this, mine did the same thing. I sent it in to the manufacturer and they told me it was unfixable and my best bet was to purchase a new one. I purchased a refurbished version of the same model, and it worked fine. This is a very rare problem, and your best bet is to get rid of the camera and get a new one.
Jan 01, 2010 | Samsung Digimax L830 Digital Camera
Kodak v1253 won't start
Assuming that you have fresh or fully charged batteries installed, chances are that the problem is corroded battery contacts inside the camera. Remove the batteries and clean the inside contacts with a fine wire brush, steel wool, or fine sandpaper. Remove any residue that's in the camera from the cleaning, then reinstall your batteries. Hopefully this will cure the problem and get the camera back up and working the way it should.
If that doesn't do the trick, you might want to try your luck with the Kodak Troubleshooting guide at:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10&pq-locale=en_US
Jun 19, 2009 | Kodak EASYSHARE V1253 Digital Camera
Canon A540 powershot freezes with Zoom lense still out.
Probably the most common failure for all digital cameras, a lens error. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 08, 2009 | Canon PowerShot A540 Digital Camera
Westinghouse 1080P 42" LCD TV - HDMI stopped working
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Apr 10, 2009 | Westinghouse TX-42F430S Television
Says lens error!!!!!
A lens error requires to be sent into repairs. Give them a call at 800-706-2534 option 2.
Apr 02, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
E18 error
Hi all.
An E18 lens error or a "lens error restart camera" message is almost always a problem that must be sent in to the service center for repair. Though most often the result of a fall or other physical impact, they can occur spontaneously. Like a car stripping its gears, the lens motordrive mechanism has gotten off track. Often the camera will make a grinding noise as the camera lens attempts to track back and forth and occassionally the unit will beep several times and turn itself off.
Unfortunately most point and shoot cameras have very delicate lens mechanisms and it doesn't take much force at all to cause this to happen. Very often you may inadvertantly obstruct your camera's lens with your hand when holding the camera and turning it on. In these cases it is often possible for your lens to correct itself by actually turning the camera on and off several times (restarting camera). In the case of falls or drops, however, the impact damage is often uncorrectable by simply restarting and the unit must be sent in for service at that time.
If this happens to your camera through no fault of your own and you are still within your twelve month warranty period, simply send the camera in for service and the unit will be repaired at no charge. If you are outside of your warranty period OR it is determined by a technician that impact, liquid, or grit (sand or dirt) damage is at fault then you will be assessed a repair charge (even if within your warranty period).
Typically customers with out-or-warranty repairs will have a choice of either repairing their camera at the stated charge or (depending on the camera model) taking advantage of the Canon Loyalty Program in which they may opt to select a specific refurbished camera model of slightly higher model design - at a discounted price.
Hopes this helps.
Sincerely,
HeavyDLB
Mar 18, 2008 | Canon PowerShot S2 IS Digital Camera
Lens stuck out
If it is under warranty send it in as soon as possible. Have a brother same problem. I believe it is a known problem with Sony cameras, but you don't see that in there adds. But he sent his in they replaced the lens assembly and updated the software. His was only three monthes old at the time.
Jul 30, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Power problem with 450
The LCD goes dark after the camera has been inactive for a time, to save battery. When that happens, you can easily restore the LCD display by half-pressing the shutter. If you want to, you can turn this off by selecting menu-setup-SleepTimeout and turn it off. (I don't recommend it, though, as the LCD always on will drain your battery).
Sep 08, 2005 | Pentax Optio 450 Digital Camera
Kodak EASYSHARE V1253 Digital Camera Logo
168 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
