Question about Toshiba 50HM67 50" HDTV
I nees a cooling fan for a Toshiba 50HM67 50 inch
I need a cooling fan for a Toshiba 50HM67 50 inch DLP TV A web site to order on line would be great. All I can find are relacemant bulbs. There has to be a website with all replacemant parts. I can't be the only one looking.
Trucker I found this website....http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1089868%2DTOSHIBA&Show=ExtInfo hope it helps
Posted on Aug 22, 2009
Testimonial: "Thanks for the tip!"
Toshiba model 62MX196 t.v. 62 inch rear projection...turns on then goes black and mute after 5 secs then red led continually blinks. Unplugging and rebooting power button causes a voice to say "fan st
I'M ASSUMING THIS IS A DLP? IF SO "ANY"
I REPEAT IF ANY OF THE FANS ARE SEIZED OR DRAGGING
SLOWER THAN THEY ARE SUPPOSED TO
IT WILL SHUT DOWN THE Tv!!!!! EVERYTIME AND THAT GOES FOR ALL OTHER DLP/LCD PROJECTION AS WELL!
BY DESIGN THEY DEPEND ON THOSE FANS, WITHOUT THEM THEY WILL BURN UP THE PARTS THAT THEY ARE ASSIGNED TO COOL. THE 3rd WIRE ON THE FAN PLUG SENDS A PULSE EVERYTIME THE FAN COMPLETES A 360 degree REVOLUTION, TO A CIRCUIT THAT MONITORS IT.
Nov 15, 2013 | Toshiba 46H84 46" Rear Projection...
72hm196 toshiba dlp HD 1080. What is the problem of my tv when the yellow led lights is blinking and which parts need to fix it
It should be due to a problem to cooling fan [DLP]. If you wish to get more details about blinking codes, surf the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the model name to your set in its search box, or view it in Timeslide / Mosaic option.
Jul 13, 2013 | Televison & Video
Buzz sound from Toshiba model 72HM195
Mine is doing the same thing. I think its the cooling fan. The bearing is probably gone.
Nov 22, 2012 | Toshiba 72HM195 72-Inch Diagonal...
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Toshiba 52hmx95 dlp tv. took back cover off. the fan cooling the lamp,makes a loud humming noise.read that fan is hard to get.(this is a three wire.only finding two wire.)is there a three wire fan i can...
maxie99,
Fan is available at https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=6475656&smodel=52HM95 for about $80.00. Replacement should be as simple as unplugging the fan cord and removing a couple screws to remove. Do the work with the unit unplugged from the wall. Reverse the procedure to install the new unit.
Thanks for using FixYa and the great rating.
hardrocko
Oct 19, 2010 | Toshiba 52HM95 52" HDTV Projection...
Our toshiba 42" DLP makes an incredibly loud fan noise sometimes. Sounds like it will blow up. Can this be fixed without costing a fortune or do we just need a new set
Hello.
I can Honestly say this is little information. and i will try to you to a web site that i think it will help you and probably you can fix it by your self.
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1254&p=4208#p4208
This is what i think is the problem.
id the sound is to loud i think its the Color Wheel maybe its broken or louse you need to check and see that you color wheel is not making the loud sound!
Good Luck on fixing your TV
Mar 10, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Check fan # 2
Samsung Consumer LCD tv's do not have fans except on the higher end models. The Commercial models do. Yours is a Consumer model. I suspect that you have a DLP tv. In that case replace the Lamp Fan. It is the Larger of the three fans. With the rear cover off, you will see a Blue switch lever on the lower right side of the tv. Hold it in a up position and turn "on" the set with your tv remote. Then look for any fan that is not running. Then order that fan. there is a large fan that cools the Lamp. The other fans are of the same smaller size and one cools the DND chip and the other cools the Ballast.
Jul 04, 2009 | Samsung Televison & Video
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Toshiba DLP fan noise (52hmx95)
i constantly hear complaints about fan noise in dlptvs if you sit in front of your computer you will hear the same noise even in the next room there is no solution to the fan noise problem this product has a huge cage fan and a second and third three inch fans in it.... more than the samsung product it can be noticeable if the tv is on hard surfaces ie wood floors ,inthe corner, glass top etc the vents on the back of the tv allow for proper cooling of the lamp at shutoff so it doesnt shatter the tube its kinda like annealing glass its designed to extend the life of the lamp .... which im sure youve priced call toshiba and tell them your lamp is bad right now and get a new one for an emergency ( warranty if you can do it ) they are also improved this product is known to have short bulb life sometimes the zinging noise you hear is indicative of a bad color wheel in the light engine which would require replacement ( not cheap) toshiba will not piece out the color wheel assembly individually
Nov 30, 2006 | Toshiba 62HM95 62" HDTV
Toshiba 50HM67 50" HDTV Logo
672 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
