Question about Acer TravelMate 4150LCi Notebook
Both hinges on my laptop are broken therefore the screen does not stand on its own without support.Other than that, computer works fine
  • 130 Answers
You need to get it to a tech or return it to factory to have that display back replaced.
Posted on Jun 21, 2009
How do I fix or replace a broken Hinge on Dell 500 Laptop
The hinge rarely breaks, the fixings come loose and split the plastic case.
Disassemble the laptop to find out where your problem is,
DELL Vostro 500 PP29L SSD
If the plastic has broken off, I use epoxy resin to repair around the hinge or look on fleabay for a replacement hinge.
Dell Latitude D500 Laptop 14 1 034 Screen Hinges eBay
Feb 06, 2017 | Dell Computers & Internet
Laptop hinge wont move
I would loosen or unscrew the 8? screws that hold the display on, this will loosen it off without everything coming apart, then tilt the screen down, lift the from the bottom of the screen, pry without breaking, take that panel off and see if you can replace or find the part that came out, it maybe screws or another piece. You can probably put it back together if it fell out, then just put the screen plate back on.
Aug 23, 2013 | Fujitsu Siemens Computers & Internet
Missing Hinge, How to fix for Free?
paper clip.... make 2 notchs one in bottom of screen and one in top of computer base. and then fold the paperclip to make it difficult for it to fall back.or..tape it on the back with strong tape when its open the farthest you want. if you wanted it open to 90 degrees youd tape it there on back with duct tape and then when it trys to slide back the tape will be so tight its unable to without force. if this works let me know
Jun 15, 2013 | Dell Inspiron 1525 Laptop
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
Repair
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
Labtop broken hinges broke off computer still works fine just top monitor doesnt stay up snapped from hinges
here is a Ebay listing for laptop hinges for the 9400 series
http://cgi.ebay.com/ACER-Aspire-9300-9400-9520-laptop-17-LCD-screen-hinges_W0QQitemZ120549686747QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c11523ddb
You will have to install them or find a person who is handy with disassembling laptops.
1. You will have to remove the cover of the LCD screen and then you will see the hinge support assembly.
Here is a site that may assist you with the taking apart and assembly
http://www.insidemylaptop.com/fix-broken-dell-laptop-hinges-yourself/
Apr 14, 2010 | Acer Aspire 9410 Notebook
Broken Hinges
you have to change your hinges.Plz visit to your nearest service station.
Mar 14, 2009 | HP Pavilion dv6000t Notebook
Broken laptop screen HP Pavilion ZV6000
I have a HP Pavilion zv6000 laptop too, and I have the same problem. A year ago, the screen was getting loose and finally it just broke. Won't stand up. I've been propping it up against a wall for a year. I can see what is wrong: my laptop has gotten so hot that the back of the laptop where the hinges are has warped and ruined the hinges. Do you notice that? The split in the seem and the actual bend of the plastic? Anyway, the computer itself works perfectly. I was going to buy new hinges and replace them myself, but it was too much of a hassle, and I needed a new laptop anyway. The hinges are inexpensive. And the laptop isn't TOO difficult to take apart (search for the manual. it's easy to find). I took it apart with my Grandpa, and he's old, and I'm a girl. (okay, sexist, gender...ist.) I actually received a new laptop as a gift. Luckily. No solution, other than replacing hinges. I just wanted to let people know I too had the same problem.
Aug 13, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Acer TravelMate 4150LCi Notebook Logo
124 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
