Question about Garden
Craftsman 358.791070 overheats and locks. Cord will not pull.
    President:
  • 1,111 Answers
Make sure you have the right gas to oil mixture
Posted on Jun 21, 2009
Brand new craftsman 190cc lawnmower pull cord will not pull out
New mowers some times comes with a safety block on the blade and this has to be removed before you can turn the blades
Jun 30, 2014 | Craftsman Garden
I operate a 32cc Weed Wacker from Craftsman. It was working just fine, but all of a sudden stopped running and somehow I cannot pull the start cord, it got stuck. Where should I look first before opening...
The first thing I would do is remove the housing for the pull cord and spring to find out why it isn't pulling. That may be the same reason as to why it stopped and appeared to lock up.
Jun 19, 2011 | Craftsman Garden
How do I replace the pull cord on a craftsman 6.75 HP EZ walk?
Remove the three or four bolts holding on the pull cover and lift it off the mower.
Get a length of new pull cord and fish it into the hole the cord comes out of while passing it into the cord reel underneath the cover. There should be a hole in the reel where you can see where the cord should come out. Then you tie a knot into that end of the cord. With the cord now on the reel you wind it backwards with free end of the cable enough turns to **** in the free cord when you let it go. Usually 6-10 turns minimum. Remember to allow for the distance to the lawn mower handle! Unless your cord terminates at the top of the pull cover.
Good luck and be careful!
Oct 04, 2010 | Craftsman Garden
The pull cord on my leaf blower will not re-coil. I have it torn apart but can't figure out what is wrong. Any ideas? Craftsman 32cc 360 cfm gas
How far did you take it apart? It is more than likely just jammed, take a small screw driver and stick it in one of the fins and try to work the pulley back and forth. When you pulled it, it went past the end and pulled the rope back in when it should be pulling it one way now it is pulling it the other way and it is locked. Or the spring is broke. Not likely. Here is a video on it.
http://www.youtube.com/watch?v=zelPN20xVrM
Oct 01, 2010 | Craftsman Garden
My craftsman pull cord broke on my weedwacker
Remove the tube that holds the flex drive from the end of the crankshaft. Lossen and remove the front cover. Remove the throttle cable from the carb. Remove the kill switch wire from the coil module. Remove clutch housing. Remove clutch, Remove flywheel. The recoil unit mates with the bottom of the flywheel and all the aforementioned parts are on the front side of the engine's crankshaft. Once you get the recoil unit off, you remove the old cord and turn the unit several times to "preload" tension on it. Insert the new cord into the guide holes and tie knots to lock it in place. The pull handle must be attatched too or when you let the recoil draw in the new rope, it will keep going and all tension will be lost. Reassemble all the above and good luck
Aug 31, 2010 | Craftsman Garden
Pull cord broke on my craftsman gas push edger. I replaced cord but when I pull cord..It wont rewind but I can hear it trying to start
It sounds like you did not properly rewind the spring that is behind the spool that the cord would around, that spring is what rewinds the cord after pulling the cord.
May 05, 2010 | Craftsman Garden
Replacing a pull cord on a Craftsman mower
u helped tremondous. thank you, being laid-off i need my mower
Mar 29, 2010 | Craftsman Garden
The cord pulled out of my 32cc craftsman blower.
slow and steady, there is no shortcut for that machine, find a clean work space and start at the top. They will never win an engineering award for that one
Nov 16, 2009 | Craftsman Garden
Sweeper-mulcher starter cord won't move
yes it the locking problem for sure.calling a tech is much advisable.
Nov 09, 2008 | Craftsman Garden
Broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Sep 09, 2008 | Garden
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
