Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
I have a 72 shovelhead engine and I want to know what type of spark plugs can I use in it instead of harley davidson and also what would be the best oil to use in it instead of harley davidson also? About how many quarts would I put in it too? I think 4 but not sure. Thank you for your help!!
  • 27 Answers
Try this for your plugs - might give a couple of options. maybe a later one will do?
http://www.harley-performance.com/harley-spark-plug.html
Amsoil 20w-50? Depends where you are and what you can get. I think there is a rev-tech oil to suit your shovel, but can't remember the spec off hand. Havoline 20w-50? Oil debates seem to rage on forever on most H-D forums around the world. Have found for me the H-D stuff is about the same price as the rest, and just as good/bad as them.
As for quantity, I'm thinking it is about 31/2 to 4 quarts, as you said.
Check these guys out - maybe better answers than mine mate. http://www.shovelhead.us/
Hope this helps you.
Posted on Jun 25, 2009
1972 Harley Davidson FLH 1200 no spark
Hi, Jzpaznthru and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
77 Shovelhead turns over but no spark at plugs Harley Davidson Forums...
How to test your Harley Ignition Coil
https://www.carlsalter.com/pdfs/Harley-davidson-1970-78%20Electra%20super%20Service.pdf
http://www.harleyclasica.es/wp-content/uploads/manuales/1941-84-HD-FL-FLH-Parts-Catalog.pdf
https://www.carlsalter.com/pdfs/Harley_Davidson_FLH%20Electra%20Glide%201970%20Owners%20manual%20v2_2.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 15, 2018 | Harley Davidson Motorcycles
What is the equivalent to a 5r6a ?
If you type this question into google you will get several equivalents. You may find questions like this are more quickly answered using google rather than waiting for Fixya answers
Dec 09, 2017 | Cars & Trucks
1979 Harley Davidson Shovelhead no electrical power battery has 12.8 volts
Hi, David you may have a faulty circuit breaker for this scenario you will need your service, parts fiche, and owners manual if you can not find the best tool you ever bought for your Harley, despair not, for a mere zero $0 you can download another one.
Shovelhead Electrical Troubleshooting No Lights No Start Harley Davidson...
https://www.carlsalter.com/pdfs/Harley-davidson-1978-80%20FL_FX%20Service%20manual.pdf
https://www.carlsalter.com/pdfs/Harley-Davidson-1941-78%20FL-FX-Electra%20Glide-Super%20Glide%20Parts%20Catalog.pdf
https://www.carlsalter.com/pdfs/Harley-Davidson-1980%20Owner%27s%20Manual%20Supplement%201980%20FXWG-80.pdf
Instant Tech Relief To speak to me personally absolutely "FREE"
Aug 31, 2017 | Harley Davidson Motorcycles
Pushrods for Shovelhead
They seem to be readily available and videos of how to install. Solid pushrods available as after market items on ebay or custom shops.
How To Adjust Pushrods On S&S 117 - YouTube
z? 10:21 https://www.youtube.com/watch?v=c6Q9GpWfXAw
  1. Similar
Feb 17, 2011 - Uploaded by 1EasyCruiser 7:55. Cam Replacement on a Harley Davidson Twin Cam, including Pushrod Removal • J&P Cycles ...
Harley ShovelHead pushrod adjustment - YouTube
2q==? 9:25 https://www.youtube.com/watch?v=Br0R6GQRKwE
  1. Similar
May 10, 2016 - Uploaded by Vavuum com Thanks for posting! There is definitely a lack of good quality shovelhead maintenance videos on youtube. Read ...
S&S Cycle - Pushrod Installation Instruction video - YouTube
2q==? 9:13 https://www.youtube.com/watch?v=221SmYpU5ko
  1. Similar
Apr 5, 2011 - Uploaded by S&S Cycle, Inc This video will show you how to install and adjust S&S Cycle's solid lifter pushrod conversion kits for ...
Shovelhead Pushrods: Motorcycle Parts ' eBay
www.ebay.com/bhp/shovelhead-pushrods
  1. Cached
  2. Similar
S&S Cycle Solid Lifter Pushrod Conversion Kit For Harley Shovelhead 1966-1984. $108.95. Buy It Now. Free Shipping. 9 watching; '; 11 sold. By the Harley performance pros at S&S! FOR : 1966-1984 Harley Davidson Shovelheads. Luggage, Saddlebags. Kit includes four nonadjustable steel pushrods, four adjustable ... Missing: 73 ‎cu
Harley-Davidson Evolution engine - Wikipedia
https://en.wikipedia.org/wiki/Harley-Davidson_Evolution_engine
  1. Cached
  2. Similar
The Evolution engine (popularly known as Evo) is an air-cooled, 45-degree, V-twin engine manufactured from 1984 by Harley-Davidson for the company's motorcycles. It was made in the 1,340 cc (82 cu in) displacement for Harley-Davidson Big V-twins bikes, replacing the Shovelhead engine until 2000 when the last EVO ...
93 Ci. Shovelhead Engine - Engines ' Vulcanworks.net - American ...
vulcanworks.net/store/93-Ci.-Shovelhead-Engine.html
  1. Cached
US$5,700.00 Harley Shovelhead Engine ... Forged Steel Heavy Duty Rods, 7.440 Rod Length; Fully Pressurized Big End Oiling System ... Vulcanworks Billet Aluminum Tappet Blocks; Vulcanworks Chromemoly Pushrods; Colony Pushrod Tubes; Andrews Special Grind Camshaft, .485 Lift; OEM Style Rocker Arms, Blueprinted; Manley ...
Harley-Davidson Pushrods ' J&P Cycles
https://www.jpcycles.com/harley-pushrods
  1. Cached
55 products - Find Harley-Davidson Pushrods at J&P Cycles, your source for aftermarket motorcycle parts and accessories. Missing: 73 ‎cu
Motorcycle Engines ' J&P Cycles
https://www.jpcycles.com/motorcycle-engines
  1. Cached
Our selection of motorcycle engines and accessories includes everything you need for your Harley-Davidson, Kawasaki, Suzuki, Yamaha and Honda. If you're looking for performance, J&P Cycles has all the brands that are synonymous with horsepower, including S&S Cycles options for Twin Cam, Evolution, Shovelhead, ...
Feb 21, 2018 | Cars & Trucks
1976 harley davidson electra glide shovelhead valwe adjustment
Hi Hanci, for more information about your question please visit the websites below. Good luck and have nice day.
Shovelhead Pushrod Adjustment
Aug 27, 2012 | Harley Davidson Motorcycles
How to take cam out of a 1977 shovel head
Hi Homeboy, for more information about your question please visit the websites below. Good luck and have nice day.
Harley Davidson Shovelhead Engine rebuild 01
Aug 25, 2012 | Harley Davidson Motorcycles
How do i rebuild a 1972 shovelhead harley primary unit
To rebuild the primary of '72 Shovelhead is far too much to type out here. Besides, you'll need some pictures to help you identify a few things. You know the saying, "A picture is worth a thousand words". In this case, it's true. I'd suggest that you purchase a service manual. The best one that I've found is a Clymer's Manual, number M420 for Shovelhead 1966-1984. The factory manuals have been condensed so much that I think they rank second to this book. If you have a specific question, I can help there but to type out the entire process would be like me writing a book but without pictures.
Good Luck
Steve
May 14, 2011 | Harley Davidson SportClassic PaulSmart...
How to time spark
To be perfectly honest with you, I don't know how to set the timing on a Twin Cam because I don't work on them. I do work on all Harley's prior to the Twin Cam.
With that being said, the way we'd do it on an Evo engine is remove the timing plug on the left side of the engine. Find the advanced timing mark and use a strobe light to check the timing with the engine running fast enough so that it would be at maximum advance. If we had to change the timing, we'd loosen the sensor plate in the timer cavity on the right side of the engine and rotate the plate in whichever direction we needed to move the timing, clockwise to ****** the timing, counterclockwise to advance it.
However, the Twin Cam gets it's timing pulses off of the left flywheel in the crankcase. Since it uses those pulses to determine the position of the crank, the timing may be set electronically instead of physically moving something. Maybe I'll buy myself a manual and see how Harley does it for myself.
I'm sorry I can't help you but I've got all the work I can handle working on the older bikes from Panheads, Shovelheads, Ironheads, Evo, and even the Italian Harleys and Hummers. I'm working on a Harley Topper right now for a guy.
Good Luck
Steve Bentley
Forsyth, Ga.
Sep 16, 2010 | Harley Davidson FLHTCUI Electra Glide...
The bike is a 06 streetglide when you throttle the bike under load the oil pressure drops what would be the cause
I don't know too much about the oil pumps in the Twin Cam engines. I have never worked with one of them but I've got extensive experience with the older type pump used on the Shovelheads and Evolution engines.
A Harley engine employs a high volume low pressure oiling system. The old Shovelheads would actually show no oil pressure when idling hot with most gauges. The oil pressure switch would cut the light off at four pounds of oil pressure. A Harley engine will not hold a lot of oil pressure because the engine is built using roller bearings instead of shell bearings.
As long as the tappets are not rattling, you don't have a problem with oil pressure. If your oil pressure drops too low, the tappets are hydraulic and they will rattle like hell. There will be no doubt in your mind as to the problem.
Now, back to your question as to why the oil pressure on your bike drops when accelerating under a load, I have no idea.
Good Luck!
Steve
May 18, 2010 | 2008 Harley Davidson FLHX Street Glide
1972 shovelhead engine needs spark plugs and oil!
I have a 75 FLH and I use the Bosch Platinum WR8DP if you have the long plug if you have the short one it is W8AP, they are an exelent plug. As for the oil I use Rev-Tech grade 60 but you should stick with one kind of oil and for a FLH it is 4 qts.
Jun 21, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
380 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
