Question about Dryers
Kenmore 63942 air coming out of bottom of dryer
Check the vent outletin the botten of the unit
Posted on Jun 21, 2009
The bottom panel ( below the door)has come loose. I would like to see a picture of the dryer housing to see how it comes apart to enable me to fix the lower panel.
Copy and paste this service manual site for your washer design.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
Dec 12, 2010 | Kenmore 63942 Dryer
I have Kenmore dryer, which was running fine until the last load. The hot air is coming inside, but clothes are not drying since it was not turning around. I cleaned the vent, please let me know, what...
The problem is likely the dryer belt . Here is a video on replacing a dryer belt. It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Sep 19, 2010 | Kenmore 63942 Dryer
63942 Dryer: runs air no heat , timer does not move...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
May 18, 2010 | Kenmore 63942 Dryer
My Kenmore elite dryer quit blowing hot air, what should I check first?
remove the bottom panel and check the fuse and the heating element ,the fuse is on the left side of heter box near the back and the element is in the heater box
May 03, 2010 | Kenmore 63942 Dryer
Kenmore HE Dryer not blowing hot air
I have a gas kenmore dryer... the drum runs- it blows air and for just a few minutes warm air but after a few minutes the air is cold. I have cleaned the vent checked it good. I didn't see the fuse on the back I have the bottom latch open and see several wires that can be disconnected; snap together.
Mar 10, 2010 | Kenmore 63942 Dryer
My dyer does not get hot.
change your high temp thermostat,remove back panel and it's on your right bottom of box-mike
Jul 16, 2009 | Kenmore 63942 Dryer
Cant locate vent exhaust
the vent come out at back or sometimes bottom side you cant miss it
Jun 21, 2009 | Kenmore 63942 Dryer
Model # 63942/01 drum works fine but all of the sudden no heat.
Remove the backside and check your heating element and the limits mounted on the side at top and bottom.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 01, 2009 | Kenmore 63942 Dryer
Putting Belt back on Kenmore Dryer 63942
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the drum out, clean out the dryer witha vacuum and use this belt routing pic for reference:
CLICK HERE
Dec 23, 2008 | Kenmore 63942 Dryer
Kenmore 80 series dryer
check to make sure you have 220 volts to dryer. if so check element for continuity make sure power is off
Dec 08, 2007 | Kenmore 63942 Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
Marvin
Marvin
