Question about Briggs & Stratton 50-Amp Automatic Transfer Switch - 1918
I'm wiring a briggs and stratton 1918 automatic transfer switch. how do i wire the chosen circuits to be powered? would they be wired exactly as if they were at the main panel?
  • 744 Answers
With any transfer switch, automatic or otherwise, there are three (3) connections:
1. The normal feed (from your local utility)
2. Emergency feed (from your generator)
3. The load (your power panel or other electrical loads)
The transfer switch should be marked "N" for normal, "E" for emergency, and "L" for load
If you want individual circuits, then you will need a second power panel to separate the circuits.
This can be tricky, and if you are not familiar with transfer switches or emergency power, it's best left to a licensed electrician.
Posted on Jun 24, 2009
  • seapower67 Sep 19, 2011
    The power connections seem clear, it is the control connections that are the problem with the documentation. Are there any schematics for the actual generator controller that are better than the manual? Those are unclear.
Need wiring diagram,from alternator to plug-ins for briggs & Stratton (3500) Elite series Model # 030208-0
No wiring diagram available from Briggs. Try re-magnetizing the rotor. No AVR or Capacitor listed in the parts list.
Disconnect the wires to brushes ( pay attention to the order) and apply 12vdc to brushes. Positive goes to brush closest to the bearing. Start the generator and check for output. If output is normal run the unit a few minutes to ensure re-magnetization then shut down normally. After shut down disconnect the 12 vdc source and re-install the previous disconnected wires. Now re start the generator and test for output should be okay provide there is no problems with the alternator. If no output during the above re-magnetization then your rotor windings my burned out.
Oct 10, 2014 | Briggs & Stratton Gas Powered 3500-4375...
Need to know how to wire a coil on a Diamond I/C 20 hp briggs & stratton motor
Black wire should be an earth for the stop switch. needs to be attached to the switch but not directly to earth
Apr 20, 2013 | Briggs & Stratton Garden
Briggs and stratton 10 hp model 19e412 broken on/off switch
do you have a diagram of the switch wire connection fro model # 19E412
Sep 26, 2012 | Briggs & Stratton Power Products 5,550...
Engine wont shut off
the wires going to the coils are shutoff wires you can run both to a switch and then a wire from the switch goes to ground when you flip switch it grounds the coils shutting off the motor
May 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard Briggs & Stratton won't shut down
Your kill wire from the switch to the coil is bad,disconnected or connections dirty...or switch is bad...try disconnecting the kill wire on the coil and using a jumper ground the coil directly to the engine or frame it should shut down if it does it is the wire or switch do the same at the switch if it shuts down it is the switch..if not the wire has a break..good luck..
Feb 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
How to fix an off and on switch on a briggs and straton model series, 19e400 5000 watt, on and off switch located on top of the motor. is there a wire thats supposed to hook onto the switch somehow.
Kill switch should have a wire connected to the tab on the spark coil under fan cover. The switch is a means of shorting kill wire to ground. On some generators, there will be another method of shutting down the engine. Usually on/off switch will be more visable on the control panel. Most likely the switch on fan cover was not connected to prevent confusion.
Sep 14, 2011 | Briggs & Stratton Briggs and Stratton...
The generator doesn't turn off after transfering power back to the utility
The transfer switch is responsible for starting / stopping the generator. Check your auto - start circuit. It is 2 wires that go between the genset and ATS. They are generally normally open. When the genset is to shut down this circuit needs to change state.
Jul 09, 2011 | Briggs & Stratton Briggs Stratton 7 kW...
I have a Briggs & Stratton Automatic Home Generator 7 kW, Model# 40301. I had it installed by an electrician. Who also installed Briggs & Stratton Transfer Switch 50 Amp. The problem is the...
It sounds like the mains sense wire is disconected from the control panel or the run wire is not being cut by the aux contact on the transfer switch.
Is the transfer switch manual or motorised?
Feb 15, 2011 | Briggs Stratton 7,000 Watt Automatic Home...
Does 200 amp supply need 200 amp transfer switch
Yes this is true, any means of disconnect has to have the amperage rating of the supply otherwise a fire can occur from overheating of wires and connections.
Jun 24, 2010 | Briggs & Stratton 100 Amp Transfer Switch...
50 AMP EXTENSION CORD
6/3 SJ cord will carry this load for a 25 foot cord.
Jan 19, 2009 | Briggs & Stratton 50-Amp Automatic...
Briggs & Stratton 50-Amp Automatic Transfer Switch  - 1918 Logo
239 people viewed this question
Top Briggs Electrical Supplies Experts
John Trevino
rlev_7
Level 1 Expert
ray012965
Are you a Briggs Electrical Supply Expert? Answer questions, earn points and help others
