Question about Dryers
Hunter ceiling fan that is 14 years old is making a load noise at times when it is on, especially when it's on high. It doesn't always make the noise. I've checked the blades to make sure they were tight.
    Sergeant:
    Champion:
  • 240 Answers
Sounds like the motor bearings>? Sometimes this has a bit of a "squealing" tone. Either replace th motor or decide that the fan has had its life and replace it.
Posted on Jun 21, 2009
Have a hunter 52" insignia
Diane, usually, that's an indication that one or more of the fan blade irons are loose, where they attach to the fan's motor. Unfortunately, you're going to need a tall ladder and a Phillips Head Screw Driver to reach and tighten the screws. You'll have to check each fan blade iron one at a time, to find the one(s) that are loose.
Good luck. I hope this helps you solve the problem.
Jul 09, 2011 | Hunter Heating & Cooling
My Hunter ceiling fan make a clicking noise whenever I have it on a high speed. If I put it to medium it doesn't make that sound. I actually have the same problem with my other fan. One is in the...
You need to balance the fan blades. There should have been some small metal pieces that came with the fan. I you can not find the pieces, your local Lowe's or Home Depot carries them in the lighting area.
Jun 22, 2011 | Heating & Cooling
Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
How do I oil my Hunter fan?
You don't. There's no place to oil ANY ceiling fan, not just the Hunter line. All ceiling fans use sealed ball bearings in the motors. They are lubricated for life. If you're experiencing a squealing noise, it would be best to take it down, pack if up and take it back where you bought it. No ceiling fan should squeal, let alone one as expensive as a Hunter.
Apr 22, 2011 | Hunter Dryers
Hunter Ceiling fan lost medium speed, kept hi and low. Speed control capacitor melted. Replaced both capacitors (speed and start) AND switch. Still no medium speed. Is it possible part of the motor...
well, they could have. but before you throw it out, go to the hardware store, and buy a new pull switch. either that, or just run it with the high and low speeds. It shouldn't hurt it at all. But, if there is any clicking sounds, or wierd noises coming from it , DON'T USE IT!! it may catch fire. but it did last a long time. 20 years is good for a modern celing fan. though I like my antique 1907 westinghouse 72 inch 2 blade fan. It hasn't died yet!!!
Aug 12, 2010 | Hunter Ceiling Fan Control Switch
I have a 52" hunter ceiling fan. It is 10 years old. Only the high speed works now. I small controller in which the switch is connected to seems burnt. It is puffed on one side and hard carbon on the...
mcdevito75 here, You can check with any store that carries Ceiling fans for replacement parts, and contact info, you can check online at Hunter fans.com hope this helps.
Aug 05, 2010 | Hunter (25417) Ceiling Fan
Moves to much when on high and makes noise. It
mcdevito75, I would have a handy man look at the Fans hook up to the ceiling to make sure it:s still tight. The fan vibration could have looened it from the ceiling do not us efan on high till it:s checked, handy man / women in every area, just ask around.
Jul 18, 2010 | Hunter (25417) Ceiling Fan
52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
I have a hunter ceiling fan its about 20 years old. my problem is the remote will not work the fan. when i have the fan set on high speed the remote will only work the high and when i set the the fan on...
I'm sure you put fresh batteries in the remote...right? Most of the time you can correct remote problems by carefully taking the remote apart and cleaning all the contact points with a pencil eraser.
Jul 26, 2009 | Hunter 21564 The Brunswick Bronze Ceiling...
Ceiling fan makes a clicking noise
just apply some lubrication and if necessary change the ball bearings. u r all set
Oct 07, 2008 | Hunter Dryers
Dryers Logo
167 people viewed this question
Top Dryers Experts
