Question about Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Remote is not working, channel up and down button
We purchased our tv May 17, 2008 and the up and down channel button has stopped working, Is there a way to fix this or is is possible to replace this remote with a new Sony one. Surly the remote shoud work for more than a year, there are no children in this house so it has not been misused.
Kay
  • 59 Answers
Try reprogramming it to the TV There are usually multiple codes for a TV and sometimes you can get one where everything works except for 1 button. Look in the user manual. If the TV is sony then contact sony...sometimes they will ship you a free one depending on how old the tv is.
Posted on Sep 19, 2009
I do not want to purchase information. I would like to know if I can purchase a new remote!!
Posted on Jun 22, 2009
Getting a specific channel on the TV without using a remote
Usually if you go into the setup menu, there is an option to allow you to either "scan" for a channel, or "input" a channel. In this case, select "input" and see if the TV will allow you to press the up and down channel buttons and go to a specific channel. If so, when you get to channel 4, press the "add this channel" option (or whatever the menu option says) and you should then be able to go to channel 4 using the buttons on the front without skipping over it.
Jan 24, 2010 | Televison & Video
I have a emerson 32 inch tv ewf2702. The remote does not work
try scanning your TV channels down or up depending how close you are to the first or last channel you have programmed, if you continue to move past those settings you should come to the game channel for your TV, if it does not go into your menu>channel settings>manual settings, scan to the game channel and make sure it lists as active if not make it so.
Dec 07, 2009 | Televison & Video
Channel Up/Down button quit working on the remote control
I had the same problem. You need to go into SETUP > CHANNEL > SKIP and select NO for every channel with a signal. A few months after we purchased the TV it defaulted to this (software glitch). We had lived with it for months before figuring this out. There is no easy way to reset these that I know of. I literally had to go to each channel and then change "skip" to "no." JM
May 24, 2009 | Polaroid 1911-TLXB 19 in. LCD TV
Mitsubishi WS-65611 tv channels cannot stop scrolling
Check to make sure the channel down button is not stuck. If it is not the button is probably defective. Mits has had a lot of problems with the buttons.
Jan 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Oct 04, 2008 | RCA TruFlat 27F520T 27" TV
Hi there!
I think your remote may be at fault. Liquid spill or sweat from the hand accumelates on the inside over some time and then becomes sticky. Some of the buttons may be permanently activated. Then other functions won't work. Have someone check it for you or if familiar yourself. Regards, JUS004
Mar 12, 2008 | RCA TruFlat 27F520T 27" TV
Philips universal remote codes
For the majority of phillips/magnavox universal remotes: Hold code search button down till red light satys on. Press the tv button and the red light should blink and stay lit. With the tv on, push the power button repeatedly until the tv turns off.(dont push the power button again after the tv turns off or it will go to the next code). Push the mute button to save the setting.
Feb 07, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Turn tv on, and it scrolls through the channels
Had the same problem, channels would not stop scrolling.
It was as though someone had there finger on the channel up button.
Disconnected the sixth wire, starting with the black wire on the wiring harness for the front buttons, on/off, ch. up/down, vol. up/down, etc.
It works fine, no more unwanted channel surfing!!
Aug 29, 2007 | GE 32GT740 32" TV
After programming my new universal remote, the tv keeps changing chanels! wont stop!
you need to program your remote control. take the battaries out. and maually turn the tv on. then hit the source you want to view. for example, I want to control the tv set. I push, code search and hold it then push the source button and then release the source button and then release the code search button. now, aim at the tv and then keep pressing power button till it goes off. when the tv is off, hit return or set or something like that.( every remote has different calling for it but still the same function) it should work. try it and let me know.
Mar 06, 2007 | GE HO976855-Device Universal Remote with...
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Sony BRAVIA KDL-40V2500 40 in. LCD HDTV Logo
568 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
