Question about AEG L86800 Front Load Washer
AEG 86720 washing machine, error code CE plus various ltgs flash, think this is a pump problem,pump very slugish sounding ? anymore advise or am i on the right line.
5 Suggested Answers
SOURCE: AEG Lavamat 86720 washing machine
FAULT CODE C 9
Posted on Aug 17, 2008
  • 3230 Answers
SOURCE: aeg washing machine fault code
This error code means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Posted on May 06, 2009
SOURCE: AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
Posted on Jun 15, 2009
  • 6277 Answers
SOURCE: I have mislaid my instruction
Unfortunately this forum does not supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C.
Posted on Mar 26, 2011
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
What means Error Code CE on a AEG 86820 Update washing machine?
The water distributer is out of order there are little plastic wheels 3 of them one orange, yellow and white, the orange is most likely stuck so you have to replace the hole water distributer app. $ 100.00 for the part.
Jun 07, 2014 | AEG Washing Machines
What is error code F2 on my AEG washing machine
I believe that this is a "Pump Blockage" error. You need to locate and clean out your empty pump filter (Probably behind a little door on the bottom of the machine. You may also need to check the empty pipe and the drain it goes into are also clear. 99% probability of a blocked filter
Jul 01, 2011 | AEG Washing Machines
Aeg oko lavamat 72600 update, ce error code showing any idea?
error code ce is a faulty water distributor fault . you have to replace the top part of the soap dispensor compartment. sometimes you can hear a clicking noise when its trying to operate
Jul 09, 2010 | AEG Lavamat 72640 Front Load Washer
Flashing ce
Most all error codes on a Calypso end up being a pump problem. If all the water can't be pumped out, the tub gets too heavy for the motor to handle and it will cause a CE error code. Something like lint or wire or screw may be caught in pump impellar. If your not familiar with repair you need to call for service.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
AEG LAVAMAT 74620 shows "CE" error
I fixed it, but I still don't know for sure what the "CE" error code is. I guess it is for the water distributor. I opened it up. There are some gears in there that move a mechanical arm that distributes the water into different containers. The mechanical arm moves around an axis -- it was very difficult to move, so the gears kept slipping. I opened it, and put some greaze inside. Closing it up was a real pain. But it works, and I didn't have to wait around to receive a new distributor.
Dec 27, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Aeg washing machine fault code
May 08, 2008 | AEG L86800 Front Load Washer
AEG Lavamat 86720 washing machine fault code C3 with buzzer and pre-wash and main wash lights flashing
This means your water sensor has detected a leak. it will stop when the sensor is dry.
post further comment for more help......
May 05, 2008 | AEG L86800 Front Load Washer
AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
Aug 27, 2007 | Washing Machines
AEG L86800 Front Load Washer Logo
652 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
