Question about HP Officejet 5610 All-In-One InkJet Printer
My Officejet 5610 doesnt scan on Fedora 11
Heres what I get when I try to use xsane:
Failed to open device 'v4l:/dev/video0' (it is usb-connected to my DELL XPS M1330 laptop)
Heres my output from sane-find-scanner:
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x03f0 [HP], product=0x4f11 [Officejet 5600 series]) at libusb:005:002
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
Results of scanimage --list-devices
device `v4l:/dev/video0' is a Noname Laptop Integrated Webcam virtual device
2 Suggested Answers
ThiruBulls
  • 103 Answers
SOURCE: HP Photosmart C4200 will not scan photo to Windows XP computer
hi, here wht u need? http://h10025.www1.hp.com/ewfrf/wc/product?product=3192753&lc=en&cc=us&dlc=en〈=en&cc=us
Posted on Aug 21, 2009
I need Fedora 15 drivers for a MultiTech MT5634ZBA modem... ugg.
You must have the most recent kernel, 2.4.2 or higher. You will also need specific modules for installation, they are explained below. The MT5634ZBA-USB has been tested successfully in Mandrake 8.1 and RedHat 7.2. Please read the whole document, as some steps depend on how the Linux system was built. You need to select the USB Modem (CDC ACM) support kernel option. If you build as modules, you need to install the acm.o option. You need to set up the device node entries for the various modems. You can use up to 32 modems with this driver. Use the following commands to set up the first four: mknod /dev/usb/ttyACM0 c 166 0 mknod /dev/usb/ttyACM1 c 166 1 mknod /dev/usb/ttyACM2 c 166 2 mknod /dev/usb/ttyACM3 c 166 3 You should now be able to use a terminal emulator program to attach to this device and connect to your modem or other terminal device. If your current version of Linux has the ACM driver compiled into it, then you're ready to roll. If it has the driver built as a module, then you'll have to enable the driver with the following command: modprobe acm At this point, you may have to unplug the modem's USB cable and then plug it back in (this isn't necessary if you're using kernel 2.4.X). You should see the modem's lights come on. If you see some activity lights on the modem, type the following: lsmod This command will display a list of loaded modules. The ACM module should be displayed as loaded. Now that you've got the driver loaded, you need to set up the device node (in /dev) for the modem. You can use up to 32 modems with this driver, but most people will only need to configure one. To set up a modem, use the following command: mknod /dev/usb/ttyACM0 c 166 0 You should now be able to use a terminal emulator program to attach to this device and connect to your modem or other terminal device. Going one step further, you can set up a symbolic link from /dev/modem to the ACM modem device. This is accomplished by using the following command: ln -s /dev/usb/ttyACM0 /dev/modem That way, KPPP and related applications can all refer to the modem as /dev/modem without caring what type of modem it is. Models: MT5634ZBA-USB If the above document doesn't get you going, send me a private email & I'll have a Multi-Tech Systems, Inc. Technical Support Rep. get in touch with you ;-)
Aug 27, 2012 | fedora Linux Operating System
My Officejet says there is no computer connection but it is connected in all areas.. it then says... NO scan options???? WHAT IS THIS ALL ABOUT it was and has been working fine.....
Try scanning from your computer instead of using the printer controls. Go to your control panel and open up your devices and printers. Right click on your printer and select "Start Scan."
May 02, 2011 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-in-One
this is may be usb cable problem but you follow this steps to get solved Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online. Also I suggest you to change the usb port and the cable also still if you facing the problem follow these steps, right click on my computer and go to properties then hardware in that click on device manger and check there is any other device is listed if it is there just remove it and click for scan for hardware changes when he prompt for driver reinstall the driver cd.
Dec 02, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 5610/XP Pro- won't scan- "An error occurred communicating with the scanning device. Ensure proper connection and try again"- Connection is proper-
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr7
Aug 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Hp officejet 5610
There might be some issues either with the printer cable or the USB port on your system... Just try another cable if you have one... or u can also try another usb port on the system...
Jan 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Haris22
What have you done to make it work in Linux? If you open a terminal and plug in your camera, what do you see when you type in 'dmesg'? If the camera is able to be identified then your kernel has support for it. If it registers it as an unknown USB device, then you will need to recompile your kernel with support for USB webcams and v4l (video for linux). Also, do you have any v4l applications installed? Gnome Meeting is a good client to test to see if a webcam is truely working or not. Also take note of the camera /dev device location so you can configure another client to work with your webcam (such as Yahoo Messanger).
Hope this helps.
Oct 18, 2008 | A4tech PK5
The scanner dont work in my HP officejet 5610 all in one
This is a known issue with HP printers. Do not worry, if you get this message that the scanning software could not be found the please go to the link
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the Operating System.
From the list select. ... HP Full Feature Software and Drivers
Then scroll down to the 3rd option......
Click on Download only >> Save the file to the desktop.
Start installation and make sure that the Printer is not connected using the USB cable to the computer.
While installing, you will get the option to connect the printer. Do not connect the printer.
Select the option "I will connect it later". Go next the installation will be complete.
After the installation is complete...leave the CD inside the computer.
Connect the computer and the printer.
It will show you the configuration window.
Wait until you see the "Start using the device" option.
Click on "Start using the device".
You should see the solution center window now.
If it is succesfull. Try scanning using the Solution center.
If it is succesfull, you can now scan using the printer as well.
Try it and let me know if it works and please let me know your issue in detail.
Aug 03, 2008 | HP Officejet 5610 All-In-One InkJet...
Can not scan
For Windows Vista: which is not on HP disk; cd version 5.3 0b
Scan with "PAINT"
1. Click Windows(start).
2. Click All Programs.
3. Click Accessories.
4. Click Paint.
5. Click File
6. Click From Scanner or Camera.
7. Click Scan.
Nov 25, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
452 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
