I'm not sure which wires to attach back to the board after replcing them for new hard drives. T5230 64 bit vista amd processor
SOURCE: emachine t2824 board diagram
Here is the diagram that shows you how to hook up the wires:
http://www.fixya.com/uploads/images/284ECAC.png
If you still have no video then reseat the memory one stick at a time in one slot at a time.
If you still have no video then reseat the cpu into its slot.
If still no luck try a different stick of RAM by trying it one slot a time.
Last step, unhook the power connectors from your device so the only power connectors that are connected are the power to the motherboard and the p4 connector to the motheboard. Also make sure your power supply is set to 115v. Its the red switch on the back of the power supply.
If none of this works, then the motherboard is bad. Hope this information helps.
Ben
SOURCE: what type of motherboard i have on emachines t6212
emachines t6212 uses the ATI Radeon Xpress 200 chipset which is Compliant with the PCI Express 1.0a Specifications
Testimonial: "the info was vert helpful thank you"
SOURCE: I have a msi ms-7399
Looking in the net I found someone running an E8500 on this board so I guess an E8400 will work fine.
SOURCE: T3624 E MACHINE MOTHER BOARD DIAGRAM
my motherboard can't support of any operating system plz give me
the solution of this prob... ([email protected])
SOURCE: getting on board vga video to work on asrock
As per discription provided by you, Suspect the physical RAM is having problem. Check and insert the RAM properly may solve your problem.
Hope the above solution may resolve your problem. Please give us the feedback on the solution to provide the best resolution in future.
Revert Back for more assistance or clarifications.
