Question about Lenovo ThinkPad T61 Notebook
LCD flashing I had left my Thinkpad T61 plugged into 110 power over night. This morning when I turned it back on the monitor began flashing on and off. After a while it began to flash slower and I can see my home page. I am still able to open my documents and get on line. I am wondering if the lcd and or the inverter might be gone. I purchased this Thinkpad 6-18-08.
  • Lenovo Master
  • 4,806 Answers
If the screen is just flickering on and off then chances are that there is a loose connection on the inverter, this type of fault can happen over time and is mostly due to opening the lid and closing it.
If you want to tackle the problem yourself the inverter is located at the bottom of the screen and is hidden behind a piece of frosted plastic.
For most people this is a fairly easy job as it just involves removing the screen bezel (plastic screen surround)
If you need any more advice please post back
Regards
Posted on Jun 21, 2009
  • 37 Answers
Sounds like the inverter try ebay for a replacement
Acer monitor will not start, power button flashes
hi Samuel.
this is all i could find from the internet.
You can try a power reset to see if that helps. To do a power reset, unplug the power cable and press and hold the power key for 10 seconds. Then, release the power key and plug the monitor in and attempt to use it. If you are still unable to get a proper display, We would suggest contacting technical support to inquire about warranty repair options. Many of our monitors carry a 3 year warranty, so there is a chance you may still have warranty left.
Acer Service and Support
you could also try this link out.
Acer 22 X223w LCD Monitor will not start up Google Search
Dec 14, 2017 | Acer 22" X223w LCD Monitor
I have a Lenovo T61 laptop. Upon powering on the laptop, I noticed that the screen had become a bit "pink" in color, on the lower left side of the screen. A few days later, the screen started...
Welcome to Fixya
Plug in the external monitor to the laptop and turn on the system. Wait for 3 mins and Press Fn and F2 to switch the screen to your external monitor.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Jan 22, 2011 | Lenovo ThinkPad T61 Notebook
HP vs17x flat screen monitor won't come on, blue light flashes.
Try taking on the back of the monitor and pulling the power plug all the way out of it for about five minutes and then plug it back in and restart the computer see if it solved it thanks
May 27, 2009 | HP vs17c 17" LCD Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
My laptop won't turn on
Charlotte
Can you remove the battery? If so pop it out and leave it out for a couple of minutes then pop it back in and see what happens.
Regards
Nick
Oct 26, 2008 | Lenovo ThinkPad T61 Notebook
Strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
HP won't power up
Your main board is having a problem.
Nov 16, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
DCLCD 19" flatscreen won't turn on correctly
Same problem here, but after using the plugging/unplugging method it eventually stopped all together. So, I took it to a local monitor repair shop (AM Stereo, Seattle). The problem is a power supply issue where the capasitors go bad. They fixed the monitor by replacing the capacitors for $70. In there experience, all monitors, regardless of brand, tend to use the same cheap capacitors which fail. He replaced them with better quality capacitors which may make this monitor better than it ever was. I'm back in business with a great monitor!
Oct 31, 2007 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
Lenovo ThinkPad T61 Notebook Logo
162 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
