Question about Ovens
How do I replace the power relay board on a jenn air model w131
  • 1214 Answers
SOURCE: How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Posted on Jan 16, 2009
sclarke7
  • 222 Answers
SOURCE: Jenn-air stove Model SCE30600B. Won't heat
check all the wiring at the main bus, and at the board connections could be a bad board
Posted on Oct 08, 2009
SOURCE: My jenn-air self-cleaning electronic wall oven
One of the 2 hot wires is out. Flip (hard) the oven circuit breaker to the off position, and then back on. If it did not help - verify 220-240v between the two hot wires on the terminal block behind the electronic control. If there is less - call electrician.
Posted on Oct 14, 2009
iwillfixforu
  • 619 Answers
SOURCE: I have a Jenn Air W131 model wall oven and I
If this is the problem no it isn't hard at all. Should be able to change right thru the oven without pulling out of wall. Make sure power off while doing this tho. But ist make sure broil does work.
Posted on Feb 02, 2010
Testimonial: "Thank you very much. I will give it a try."
mc1bean
  • 3053 Answers
SOURCE: Jenn-air Wall Oven Model W131. Control panel is all dark and not
Hello, rmk
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and fartherback, It appeared that no one answered some of them, So, I thought Iwould take some of my personal time to see if I can help. Even though this sitemay not have your exact model or brand, this link will help you tons. Here is alink to about everything you want to know about your oven, from
repairto trouble shooting it. Even pictures and video's. Just scroll around and youwill see tons of information to almost any question you might have on yourOven. If you go to this link and click around, I am sure you will find out somuch about your oven, you will know more than the company that made it. Thegood thing about this link is, then you can make the decision of DIY or hiringa pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help andsome kind words written would be appreciated for my free help , I wouldappreciate it. Here is also my direct link to my own pages of other areas of myexpertise for other problems you might have in Automotive,Appliance, andElectronics. Drop In anytime for my help. Thanks, Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Our display panel light went out on our model w30400p jenn-air single wall oven.
Make sure there's power getting to your range, oven or cook-top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. I would also advise to inspect the junction point on the backside of the unit for a possible separation of the power cord as well. If all checks out ok, The main control board will be the culprit.
NOTE_ If your unit is equipped with a relay board, this will be the likely culprit, if all checks out ok. If there is no relay board present inside the unit, replace the main control board.
Jan 02, 2010 | Jenn-Air Ovens
Oct 08, 2009 | Jenn-Air Ovens
I'm getting an error message F2 and the broiler will not turn off. It came on bt itself while the bake was on!
F2 on most jenn-air ranges/wall ovens indicates a fault in the oven sensor or relay board. I'd first check the sensor, (part # 12001655) it should ohm out at approx. 1100ohm @ room temp. If it is OK, it's probably a faulty "broil" relay and suggest replacing the power relay board.
The board (usually seperate from the clock and just behind it), on earlier model jenn-air/magic chef/norge/maytag etc. where known to burn up. part # VO4100260. double check those numbers with your model number at your local parts depot or service provider, those are just the most common for maytag built units.
hope that helps,
good luck
Oct 03, 2009 | Ovens
Jenn air oven problem
HI. this is a Communication error between boards. Check the wiring harness that links the Power relay board to the Main board. if the harness is fouled on any way, replace it asap. if the harness is in good condition, replace the power relay board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
F2 code on Jenn air double oven
One website said its a relay board problem. Years ago I replaced the entire electronic board and did it myself and I am not overly good at such stuff, so it can be done if you find the correct part. I am having that problem and am searching for a relay board or whatever it is.
Dec 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air coolimg fan problem
Good Morning!
What youre experiencing could be a result of a faulty oven temperature sensor, a faulty oven control board or relay board. Youre more than welcome to send both the main control board and relay board for evaluation. Fixyourboard will test and repair both as needed for less expensive than buying new, and include a two year warranty.
5700M662 60 Jenn Air OVEN CONTROL BOARD
May 15, 2017 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
148 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
