SOURCE: please help me on this.
Check the battery for charge and the connections for corrosion. Small batteries tend to lose water--check the fluid level in each cell--bring the level up to the upper line with distilled water only--not tap water. You may need to put it on a low current charger for 6-8 hours. Hope this helps!
Testimonial: "this one helped"
SOURCE: i need a clutch diagram
You can go to durantcycle.com and click on the online parts fiche then go to scooters and yamaha and then the year and the model will appear for that year. Then look up clutch and it will give you a expoded view of the clutch diagram. I hope this helps.
SOURCE: what oil does the yamaha 125 cygnus scooter use?
- The type of oil that you need to use is SAE20W40 for this scooter
- You can download the manual of this scooter on the link below
- http://www.yamaha-motor.co.uk/uk/services/owner-manuals/index.aspx?pl=EN&c=SC&m=CYG125&y=2011&l=EN
hope I answer your question. cheers!
