Question about HP Officejet Pro L7680 All-In-One Printer
The Display reads C00E0001 and also says Turn power off and on again but I cannot with out unplugging it the power button is flashing and the "!" is also flashing
  • joshua_ryan_ Jun 21, 2009
    I will try this is a new scanner lamp expensive
  • 55 Answers
This code c00e0001 is scanner lamp.
you need to replace the scanner lamp...
Removing the scanner
1. Unplug all of the cables coming from the scanner that go to electronics board. Take note of how the ribbon cables plug because they can be rotated 180 degrees.
2. Remove the two screws securing the front of the scanner. They are in the cartridge access area.
3. There is a metal bracket interconnecting the scanner and the electronics assembly. Remove the screw holding it to the electronics assembly frame.
4. Pull the scanner straight back and it will come free of the printer. Some wiggling will be necessary.
Removing the inner case
1. Remove the electronics board assembly. Unplug any remaining cables. Remove the screw above where the flat cables plugged in and loosen the three screws along the bottom edge. Release the silver latch at the top the assembly will lift out.
2. Remove four screws; one at each corner, and the inner case will lift off.
Posted on Jun 21, 2009
Why did my computer monitor stop showing an image?
Disconnect it from computer and power. wait 15 minutes and plug only the power back in, press the power on button. The monitor may display a message that there is no signal or something like that. If that happens the problem is either the cable or the computer. If you get no message then look for the menu button and press it to see if any thing appears. If not find the manual on line and read it. Many times monitors get over-driven by computers to the point that they can't display OR they self destruct.
OR
Another way is to just unplug everything computer and monitor for 15 minutes. Plug in monitor first then plug in computer and press the power button, the display should display the booting information if the cable is good and the monitor is good.
Jul 19, 2014 | ViewSonic Computers & Internet
79 error displayed power on power off and the
Hi
I can only say try it may work.
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
  • Please let me know if works for you.
  • All The Best Pineworks
Jan 11, 2010 | HP LaserJet 3330 All-In-One Printer
The power indication display is flashing with all colors visible.
The flashing will come on if the chair is in neutral or if the charger is still plugged in when you turn it on. Place the chair in neutral (freewheel) by shifting the levers out, then place firmly back into drive.
Unplug from the charger and it should fire up. Sometimes, the chair will also go into "sleep mode".
Check your owners manual for this. Note, some have sleep mode potential but it's not in the manual, and if someone inadvertantly hits the right series of motions with the joystick, you can inadvertantly put it to sleep. Try turning the chair off, wait three seconds and power back up, then immediately press the "horn" button. This wakes up most of them. Others you need to power off, turn back on and then move the joystick forward, backward then forward again.
Good luck
Jun 23, 2009 | Electric Mobility Power Electric Scooter...
No power to my computer.
hi
stuart
just read this carefully.................
Unplug the power cord and the display cable from the monitor. Now press the power button for 60 sec exact. Plug the cables and your system is working................ This is just a power drain.
Enjoy
Jan 13, 2009 | Dell DimensionTM XPS 710 PC Desktop
Power button flashes SAFE
I unplugged the unit for 30 minutes and it finally went out of safe mode.
Oct 12, 2008 | Televison & Video
Sharp AR-M205 Calling for Maintenance. How do yuo reset?
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
Sep 17, 2008 | Sharp Office Equipment & Supplies
KX-TG1000N new handset 1
For KXTG1000 only
  • The base unit must be connected to the AC adapter and the power must be on
  • Press the following sequence of buttons on the base unit: * * 3 3 5 7 8 2
  • When the display reads "Enter Base ID", deregistration has been completed successfully
  • For KXTG1050 only
  • Disconnect the AC adapter
  • Hold the Locator button down while you plug in the AC adapter
  • When the Power light flashes, release the Locator button
  • Immediately press and hold the Locator button again, and release when the In Use light flashes
  • The Charge light should flash for 4 to 6 seconds and then turn off
  • When the Charge light stops flashing, press Locator again
  • In about 20 seconds, the handsets will deregister. When the displays read "Enter Base ID", deregistration has been completed successfully.
  • Jul 15, 2008 | Panasonic KX TG1000N Cordless Phone
    Power light flashing/ no picture
    I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
    Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
    All lights flash like crazy on powering up; diagnostic says "turn power off & on"
    that is power suply broken. i already got one of those with same sintoms. you must exange it
    May 12, 2007 | HP OfficeJet 6110 All-In-One InkJet...
    Setting time after power been uplugged for 1 hr
    Is there battery backup??? if so take it out for a while and then replace with a new one
    Dec 19, 2005 | Sony ICF-C111 Clock Radio
    HP Officejet Pro L7680 All-In-One Printer Logo
    143 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
