Question about Maytag Refrigerators
Dead compressor I AM DESPERATELY TRYING TO FIND OUT THE AGE OF THIS UNIT, MODEL # LSD2615HEB. COMPRESSOR TOOK A **** ON US WHILE WE WERE GONE FOR SEVERAL WEEKS AND I AM STILL REELING FROM THE STENCH , NOT TO MENTION HUNDREDS OF MAGGOTS WHO HAD MADE THEIR HOME IN OUR REFRIG!! AND I AM MORE THAN UPSET ABOUT LOSING SEVERAL HUNDRED DOLLARS IN FREEZER MEATS ETC. WE BOUGHT THE HOUSE LAST YEAR AND WERE LEFT WITH NO MANUALS FOR ANY OF THE APPLIANCES.SERVICE MAN WAS HERE NO MORE THAN 5 MINUTES AND WAS ONLY CONCERNED WITH HIS $100.00 FEE AND NOTHING ELSE. HAD NO CLUE ABOUT ANYTHING BUT HIS FEE. I NEED TO KNOW IF THERE MAY BE ANY TYPE OF WARRANTY STILL IN PLACE FOR THE COMPRESSOR AND WHAT THE TIME LINE MAY BE. MY FRUSTRATION LEVEL IS AT AN ALL TIME HIGH! CAN SOMEONE PLEASE HELP??????? MANY THANKS, JAYNIE
  • 585 Answers
The compressor should have an ID tag on it with a type, serial number and date code indicating month and year of manufacture, but sometimes the code is alpha-numeric and meaningless without the code chart. The refrigerator should have a serial number on the same tag where you found the model number. jot that one down and contact Maytag's warranty department. They should be able to tell you how long the warranty was at the time of sale, if the warranty was transferrable as in your case, and if there is any coverage left.
Did the realtor that sold this to you also sell the property with one of those third-party home warranties? If so, contact them for more information and get this covered. That coverage is much better than Maytag's would be in a case like this.
Posted on Jun 21, 2009
Package heat pump problem.
the gauge not changing and the pipes not sweating indicates the compressor is not pumping gas
I suggest that you call in an ac specialist to properly diagnose the problem and get a quote to repair
Aug 27, 2016 | Heating & Cooling
I have a Maytag/Admiral LSD2615HEB that I need to force into defrost? How do I do that?
switch it back to defrost and open the door up completely and wait
Mar 28, 2012 | Admiral Refrigerators
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
What compressor do i need
The compressors that come in units change from year to year and model to model. Depending on the age and type of unit, it could be a Copeland, Bristol....just about anything in the 2 ton range.
Best bet would be to look down and on the top or side of the compressor, you should see a series of numbers that have the model and serial numbers. The model would be the compressor you seek and the serial will help to determine the age of the compressor. Also be sure to look for a name brand such as Copeland, Bristol, Tecumseh, etc.etc..
May 25, 2010 | Goodman CPLE24-1 Air Conditioner
Problems with GE GSL25JFPBS Side by Side Refrigerator IS THAT THE FAN RUNS BUT IT IS NOT COOLING AT ALL, KEEPING HEARING THIS CLICKING SOUND AND THERE IS NO SOUND FRON THE COMPRESSORS.
Hi, I have done commercial refrigeration for many, many, years and no about residential units also. What you need to do is to roll this unit out to get behind it with room to work. There will be a fiber like panel that has to come off. The clicking noise you are hearing is on and off every so many minutes give or take, Like, click pause click, a few minutes same thing. Anyway, remove this panel. You should see a small fan motor, a coil, and the compressor. Make sure the unit is plugged in and the thermostat control inside is set at its coldest setting. If it has been on for sometime and clicking, carefully place your hand on top of the compressor as it should be HOT! The clicking noise you will be able to here at the small cover on the face of the compressor covering the terminals and wires to start it. It also has a klixon relay wired in the common wire that when the compressor gets overloaded, it will click and keep the compressor from starting. It will continue to do this until it finally wears out. So, hearing this click and your compressor is hot to the touch, more then likely, you are loosing the compressor. Depending on the age of this unit and the cost of a tech changing it out, may or may not be worth it. Try this, unplug it. The small fan and coil, try and clean the front of the coil with a brush to remove all the dirt and dust buidup. Let the unit cool completely down. I have wet cold rags in the field and put on the compressor to speed this up, but be careful not to get water in the electrical connections. UNPLUG IT FIRST. After it is nice and cool, try to turn it on. If it starts, thats good and I cant say how long it will run. If it does not, the compressor is dead and locked up. A repairman may put a hard start kit on it to try and break it free, we do try this first, but it may be to far gone. Check the coil like I said and let it cool down. Hopefully it will run, but probably not. I hope this has given you some direction to follow.
Sincerely,
Shastalaker7
Dec 28, 2009 | GE GSL25JFPBS Side by Side Refrigerator
My dometic duo therm brisk air RV a/c unit is not cooling the RV
I had the sam problem, took the thermostat cover off and tightend and refastend the wires, so far so god
Oct 27, 2009 | Dometic Rooftop RV Air Conditioner
Warranty on compressor
The actual age of your unit can be determined by the serial number. Based on the age indicated there they can tell you if the warranty is still valid. Your local Rheem/weather king dealer can do this for you. Most compressor warranties are either 5 or 10 years. Good Luck!
Jun 11, 2008 | Weather King 10AJA2501AH Air Conditioner
Freezer freezes OK, frig compartment doesnt get cold
Does the unit only have one compressor (black round object on back of unit). If yes then sounds as though you have lost some refrigerant (just enough to keep the freezer happy). If no (ie two compressors) check if both compressors hot. If both hot then have major problem if one cold then have a thermostat gone. Personally I think you have lost gas from your description, if so then you are looking at a dead fridge freezer. Hope this is of some help.
Mar 13, 2008 | Refrigerators
Refrigerators Logo
122 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
