Question about Kenmore Elite 45986 Front Load Washer
How do we get to the basket to see why it is off balance. It is a kenmore fron load washer 3417-41142000
  • 15,935 Answers
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
My Kenmore Elite Oasis top load washer will start when is ready. We press the start button several times and hold it down for minutes at a time then maybe it will start. Plus even the smallest load will be...
If the washer is shaking and actually going out of balance and generating the UL error and the drum is empty the most likely cause of this problem is something under the spin basket.Clothes can end up under the spin basket and cause it to turn crocked and cause the out of balance. First I'd recommend removing the spin basket and check under it for any clothing or other obstruction that might cause the out of balance. Here is a diagram of how to Check.. Click Here
May 22, 2011 | Kenmore Washing Machines
Im able to start a load, water fills, washer agitates and rinses just fine. However, once the spin cycle starts, the washer starts to make an extremely loud noise (similar to when it is off balance) and my...
If you can move your basket up and down your spinal is broke at rear of basket..You would need rear tub and inner basket for that repair......If this helped please vote need more help please ask...
Feb 03, 2011 | Kenmore 24032\24036 Top Load Washer
My duet makes a loud (out of balance sound) when spinning @ high speeds. (it's not out of balance tho) the outer plastic drum seems to have a groove worn into it
The problem is the dreaded broken spinner support or what is called the spider assembly. It is the three-arm assembly that holds the basket to the shaft. Unlike the basket which is stainless, the spider is made of aluminum that corrodes with time and usually breaks during the 6th or 7th year of the machine.
The bad news is, the spinner support cannot be purchased separately. It comes as a complete assembly with the basket which is covered by at least a 10-year warranty. The most frustrating fact is that the spinner support is not covered by the same warranty even though they come as an assembly which costs at least $500, a non-economical repair to invest.
Here are some videos of owners of Sears Kenmore Front Load Washers who had an issue with the spinner support. Most Sears Kenmore Front Load Washers are manufactured by Whirlpool like the ones in the videos.
Aug 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spins out of balance even emty
http://www.askmehelpdesk.com/plumbing/whirlpool-out-balance-spin-cycle-18991.html
http://fixitnow.com/sbrvrs/washers.htm
http://www.repairclinic.com/Washing-Machine-Troubleshooting
This model of washer does not have an out of balance cut off switch. If the load is not balanced properly the tub could hit the cabinet sides. If the unit spins evenly while empty & out of balance while loaded, I recommend checking & balancing the load. If the basket spins out of balance while empty, I recommend having the suspension springs & balance ring checked. Be sure not to wash light fabric with heavy fabric clothes. Also ensure that the adjustable feet are level, that's most important.
Aug 01, 2010 | Kenmore 24032\24036 Top Load Washer
Does Kenmore Elite washer model 110.27092600 have water in bottom section of basket? I removed the one from mine because of balance problems and found the bottom molded plastic section of the basket has...
There is always water in the bottom to help keep the tub seals moist.
May 24, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Basket is out of balance and makes loud banging noise
I have a Kenmore 24832200 and it was doing the same thing and it was because one of the springs had came off the tub...Hope this helps...
May 21, 2010 | Kenmore 24902 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite Washer top load
One or two of your suspension spring may be broken
Regards
Sep 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Kenmore 70 Series
    check the balance ring on the top of the basket it has either came loose from the basket rim or the fluid inside is not there
    might need a new one
    Jun 17, 2008 | Kenmore 24032\24036 Top Load Washer
    Kenmore Elite 45986 Front Load Washer Logo
    59 people viewed this question
    Sal De
    fordexpert
    Jim Goldsmith
    Jim Goldsmith
