Question about Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater
We have a pentair minimax 100 pool heater it was working the other day, now our pool is cold as it won't even try to ignite. does anyone have an idea as to what part to start with replacing to see if we can get it working?
  • 139 Answers
Start with pressure switch,likely out of adjustment or it could be faulty.if you're going attempt to adjust,press sw,you should be familar with using a multi-meter.improperly adj could result in ruining htr and possibly a fire hazard
Posted on Jun 21, 2009
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Gfci trips heater not turned on
GFI is Ground Fault Interrupter (or GFCI - Ground Fault Circuit Interrupter) It is doing its job, telling you that there is a short in the unit or wiring. Have a certified electrician check the wiring and unit.
May 17, 2014 | Pentiar Pentair MiniMax 100 BTU Natural...
Pentair pool heater won't lite. status light says ignition lock out. how do i fix it.
If you have a voltmeter and can follow diagnostic instructions over the phone you may be able to contact Pentair technical support and they may be able to walk you through the sequence. I hope this helps.
Aug 04, 2011 | Pentair Minimax NT Heater
Can anyone out there help? I have a 4-year old Pentair Minimax 100 Natural Gas pool heater that was working since we started up the pool in June and it suddenly stopped heating the water. Don't even hear...
you need the heaters replaced, take the model number to your local spa or pool company and they can give you the model and the booklet on how to replace. be sure to turn power off before working on it. some models have valves to shut off water so you don't have to drain it, others don't so the free manual will be very helpful. If the heaters are while and blown out then your PH level is high and you will need to adjust for that condtion, or tell people to quit peeng in the pool.
Aug 09, 2010 | Pentair MiniMax 100 Aboveground 100,000...
I have a PacFab MiniMax 100 pool heater. The pilot remains on... but the burner will not ignite unless I hit/jar the heater. Any suggestions on what may need replacement or repair?
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
Jul 04, 2010 | Pentair Minimax 100 Pool Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
Pentair MiniMax 100 Aboveground 100,000 BTU Propane Gas Electronic Heater Logo
443 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
