SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players
To ensure the satisfaction of our customers and to maintain the
integrity and quality of our products, Toshiba America Consumer
Products, L.L.C. is issuing an important product update. This is not a
safety issue.
Toshiba is committed to customer service and to continuously
improving the quality of its products. It has come to our attention
that certain DVD players bearing the model numbers SD-3980 and SD-K750
may at some point in their life stop playing discs due to a component
part failure. In such case, the error message "bad" will be shown on
the unit's display. Affected units will have "SU2" at the end of the
model name (e.g., SD-3980-SU2), which can be found on the back of the
unit.
If you own either of these models and experience the issue described
above, please contact Toshiba Customer Solutions at 1-800-631-3811 for
information on how to obtain a replacement unit.
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
SOURCE: toshiba sd-310vu dvd player makes
The motor that spins the disk rests on rubber shocks. The rear shocks wear out over time allowing the disk to set uneven and rub eventually stopping the disk and giving a disk error. To fix simply put one small flat washer under each of the rear shocks this will level the motor and stop it from rubbing.
