Question about Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW gas "drying center" has a mind of its own
I have a Maytag MCG8000AWW gas "drying center" (the double-decker). It was installed in January 2005 and worked perfectly until August 2008. It could be coincidence...or the cause of the problem, but Tropical Storm Fay blew through and caused several electrical problems at that same time. We had power surges (booms) and outages lasting a few seconds (several in a row). We do not have a whole-house surge protector, so the dryer was "unprotected". Since that time, the dryer's "brain" seems to be haywire. The upper cabinet will run with the door open. It won't turn off (my husband installed a switch to turn power off to it). It starts up by itself. It reverts to the regular heat, wrinkle release, 18 minute cycle, no matter what I set it on, the control panel, for both upper and lower flash, and light up in sequence top to bottom (like a blinking strand of Christmas lights). For the past few months, the lower cabinet has worked "ok" if I turn off the power for several hours between loads. Now that the weather has turned hot and humid in Florida, it won't work at all. It does heat up, it does turn, but it doesn't know what cycle to run, and it won't turn off. HELP!
We think one or more circuit boards were fried during Fay. We can change them out ourselves, but they are expensive and we aren't sure how to diagnose which one has failed, or if that is the real problem.
4 Suggested Answers
SOURCE: Maytag Neptune Dryer MDE5500AYW beeping and resetting itself
Ok , I replaced the control board. Still beeps continuously. Just sitting there, nothing else is on, just plugged in......beeep,beeeep,beeeeep,WTF man? I am about to turn this damn thing into an anchor and invest in more clothes lines! Maytag sucks. MAYTAG an acronym for...
Maybe
All
Your
Technicians
Agree;
Garbage...
Posted on Aug 19, 2008
heatman101
  • 43501 Answers
SOURCE: I have the Maytag MCG8000AWW gas
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
mc1bean
  • 3053 Answers
SOURCE: Had power massive power outage in area due to
Hello, shelley I was trying to helpyou out here. I am not sure if this well help you, but here is a link to abouteverything you want to know about your dryer, from repair to trouble shootingit. If you go to this link and click around, I am sure you will find out so muchabout your dryer, you will know more that the company that made it. Here Is thelink for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helpedyou at all, if you can find the time to rate my help and some kind wordswritten would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
How to take a maytag dryer apart model mcg8000aww
Go to www.repairclinic.com and enter mcg8000aww. You will be presented with a list of common replacement parts and may be able to view a generic Maytag disassembly video.
Nov 03, 2016 | Maytag Dryers
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Where is the ignitor located in the maytag mcg8000aww
inside the burner funnel tube at the bottom of the dryer below the drum,you need to remove the front panel to access the ignitor
Aug 26, 2012 | Maytag Neptune MCG8000AW Gas Dryer
Im trying to gain access to the drying center by maytag, mdl mcg8000aww. i am having trouble getting in to check the components
This not a solution, just a statement that the only way in seems to be via the front with removing everything! There is a link in here to a Service manual that shows (poorly) different stages of a tear down. http://www.applianceaid.com/pdf/16022785.pdf I think my washer not spinning out the clothes properyly has cause what every it is to break. Lots of good info on how to test the ignitor, but how to get it out is another matter. Did you have to call a tech?
Apr 01, 2011 | Maytag Neptune MCG8000AW Gas Dryer
I have the Maytag MCG8000AWW gas "drying center", it tumbles but does not have any heat. The burner lights when the cycle is started, and for a few minutes it does heat. Then the humidity indicator changes...
heatman101
May 06, 2010 | Maytag Neptune MCG8000AW Gas Dryer
Maytag MCG8000AWW gas dryer no heat
The ignitor may be bad you can chek to see if there is 110volts when the dryer is allin by unplugging the wire to the ignitor and putting using a multimeter to chek for voltage at the wires. If there is power to the ignitor and the ignitor is not glowing up then the ignitor is probably bad replace the ignitor.
Jan 12, 2010 | Maytag Neptune MCG8000AW Gas Dryer
MCG8000AWW Neptune Drying Center initially has heat, then not
hey u burned the ingniter with all that lint, so just buy it around $100 , replace it and back in business.
Feb 28, 2009 | Maytag MDG21PD Electric Commercial Dryer
Maytag Neptune MCG8000AW Gas Dryer Logo
358 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
