Polaris 380 stay on the wall
My polaris has good RPM's, lots of water pressure but when it hits the wall, it stays there until the back up valve engages. I have tried everything except replacing the pressure valve at the wall fitting. I noticed that alot of water is coming out around the release valve. Is that good or bad. It has not affected water presure to the cleaner. The jets are fine and little to no leaks around the swivels. Leslies has replaced all wheel bearings and the water management system. Belts are fine.
Any ideas?
    Top Expert:
  • Zodiac Master
  • 7,401 Answers
Try without back up valve if ok replace
Posted on Sep 13, 2017
  • David Spradling
    David Spradling Nov 21, 2017
    the water coming from wall fitting bad o ring or pegs that hold unit in wall if ok reduce pressure with valve or red and blue reducers
SOURCE: Polaris 380 not running
check the filters
Posted on May 28, 2009
SOURCE: My Polaris pool cleaner doesn't seem to have
I went to another site in my search for an answer to my cost nothing.
Posted on Aug 16, 2009
  • 128 Answers
SOURCE: Wheels on polaris don't turn. Is there a way to tighten belts
Replace the belts.($30) Tighten with an 1/8" play. Also check the wheel bearings. If the wheels wobble they also need to be replaced
Posted on Aug 23, 2009
  • 990 Answers
SOURCE: My polaris 380 wheels won't turn. the belt is
If the wheels don't turn there may be sand in the notches on the wheels, the notches may be worn off, if their is sand or dirt in the paddel wheel jet that will keep the unit from turning and again no wheel movement. All of these problems they can check in your local pool store. Stores will generely check your unit out and fix what is needed for just the price of parts to fix it when you bring it into the store.
If you have no water flow to the unit this will also stop things from working so be sure to check your finger screen before you do anything.
Posted on Aug 25, 2009
  • 16 Answers
SOURCE: do other brand name pumps work with a polaris 380
you can use a hayward booster pump or pentair letro booster pump also
Posted on Jan 16, 2010
My Polaris 380 disconnects from quick disconnect. seems like a lot of pressure behind it.??
Take out the wall fitting of each of the two locking taps are probably gone there are restricted behind the wall fitting blue or red either remove or I stall
Aug 31, 2016 | Polaris 380 Pool Cleaner - Pressure
Sport 3900 is doing wheelies will not stay level to clean
1. Check the wheel RPM. If not in the 30-36 RPM range, refer to the manual for adjusting the wheel RPM.
2. Adjust the thrust jet downward.
3. Verify the backup valve is cycling. Lift the valve out of the water and watch the jet. It should come on and go off.
4. Check for water inside the head float.
5. Empty the filter bag.
You can download the 3900 Manual from the Polaris site
It will show you how to check the wheel rpm and how to adjust the thrust jet and check and adjust the float.
Jul 06, 2014 | Polaris 3900 Sport Pool Cleaner ()
Polaris moves slow
see if good pressure from wall if ok check back up valve for leaks or swivels if ok take apart and check belts and hoses
Nov 10, 2013 | Polaris 380 In Ground Pool Cleaner
My pool is losing water when a Polaris 380 is running off a booser pump
plug both sides of Polaris hoses one at wall and one at Polaris if stops leak in Polaris line
Jun 08, 2012 | Polaris 380 In Ground Pool Cleaner
My Polaris 380 just stop moving the pump was run and had good pressure turn one wheel they all turn freely also tail dose not move
Check several things if these pool cleaners stop moving. Check the filter screen in the in-line filter and clean, if necessary. Clean the skimmer basket, pump basket, and pool filter. Check all of the hoses,
connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is between 28 and 32. Adjust your thrust if necessary to get RPM to that level.
Aug 03, 2010 | Polaris 380 In Ground Pool Cleaner
My 4-year old polaris 380 frequently blows internal tubing off ports. Do I need to reduce water flow at the hose inlet?
Once you fix the immediate problem with zip ties, check the wheel RPM. It should be between the range of 28 to 32.To check the RPM Hold the cleaner completely under the water and count the wheel revolutions for one minute. If your RPM is to high, you can adjust it at the wall with pressure relief valve by unscrwing it. Im willing to bet your pressure is excessive. This page should also help: Polaris Troubleshooting Page
Nov 02, 2009 | Polaris 380 In Ground Pool Cleaner
380 unit floats to the top, doesn't move around pool
Check the following three things. One of these should correct the problem you are having with your automatic pool cleaner.
1. Confirm that the blue
restrictor disk is installed in
the UWF to decrease water
flow. Or, install the red
restrictor disk to decrease
water flow even more.
2. Check the wheel RPM. If
more than 32 RPM, unscrew
the pressure relief valve to
decrease water flow
to cleaner. Note: The
pressure relief valve should
only be adjusted when a
restrictor is installed.
3. Verify the back-up valve is
cycling. Hold the valve out of
Jun 05, 2009 | Polaris 380 In Ground Pool Cleaner
Pool polaris 280
If the cleaner is going too fast then it is likely that there is too much water flow at the drive turbine. Is there a pressure relief valve in the water supply line (at the edge of the pool)? If so then change the tension on the spring to allow less water to get to the cleaner's drive turbine.
The speed of the Polaris is probably the cause of the front wheel lifting as well, however if (after adjusting the water pressure) the front wheel still won't stay on the pool bottom, then perhaps adjust the little jet at the back of the casing. Mine points a little "down" towards the pool floor and this tends to raise the bac k wheel (or alternatively keeps the front wheel in contact with the pool bottom or wall).
By the way, if you want to see how the cleaner works, then search for eHow and lookm at the repair/overhaul of the Polaris 180............. the mechanism is similar.
Good luck.
Feb 12, 2009 | Polaris 280 In - Ground Pool Cleaner with...
89 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
