Question about Dryers
How do you access the belt tension pulley wheel on a Kenmore Elite HE4 dryer?
  • 5,911 Answers
First, unplug the dryer. Live voltages are still present inside the unit even with the dryer turned off. Then, follow these steps:
1. Remove the lower panel under the door. The screws are located under the bottom edge. With the screws removed, the panel will drop down, then slide off.
2. Open the door and remove the lint screen. Close the door. (The reason for this is because you cannot remove the blower fan housing with the lint screen in place.)
3. Remove the blower fan housing. There should be three to four screws with a retaining clip on the bottom holding it in place. Loosen all the screws. With the screws removed, pull the housing towards you from the top first, while releasing the retaining clip. The whole unit should come out. NOTE: Some blower fan housings have a ground wire attached. Make sure you disconnect the wire if this is the case.
4. With the blower fan housing removed, you should have full access to the belt tension pulley on the right hand side next to the heating element.
Is there a reason why you need access to the belt tension pulley? If you need further assistance, please let me know. I hope this helps you.
Posted on Jun 21, 2009
Dryer slow to start squeaks
The drum is belt driven, there is a belt tensioner on it too. You need to replace the belt.
Feb 25, 2015 | Kenmore Elite HE4 Electric Dryer
What do we do to address thumping noise in Kenmore Elite HE4 Dryer?
It is probably one of the idler wheels it rotates on. Look for a flat spot and if you didn't replace the drum your self ask for your money back.
Dec 11, 2014 | Kenmore Elite HE4 Electric Dryer
Does the kenmore elite he4 washer belt go on with the ridges up or down
The ribbed side of the belt is placed against the spin basket drive pulley. The ridges are required to go to the inside in order to fit properly on the drive motor shaft. The following link explains how to properly install a drive belt on one of these front load washing machines:
http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front
If you have any questions about this repair, please post back and let me know. I hope you find this information helpful.
Jun 30, 2010 | Kenmore Elite HE4 Electric Dryer
No tension on the tension pulley.
Check that the slide/rod /bracket is not jammed on the adjusting mechanism.
Jan 18, 2010 | Kenmore Elite HE4 Electric Dryer
It starts to squeak as soon as you turn it on and gets louder and loude. it willnot stop
There is a pulley that holds the belt tight (a tensioner) that usually is the culprit. Opening the dryer differs depending on which model you have. Most open by releasing the spring clips on the left and right sides of the front panel where the top meets the front. The top then tilts back, giving you access to the screws that hold the front on, so that it too can be removed. If these instructions don't quite work, post back with the model you have and ask for how to open it.
Once you have the front panel off you can get to the pulley (underneath everything).
It needs either a drop of oil on the axle, or if it is really worn, replacement. There are also two wheels at the back of the machine that the dryer drum rolls on that might be squeaking too.
Apr 15, 2009 | Maytag Dryers
2 year old Kenmore Elite Front Load Dryer makes loud squeaking
We can fix this. your dryer has some wheels/rollers and an idler pulley they get worn and or plug up with fabric sheet guu.what you do is pop the top,that the frount off and this will expose the drum,undo the belt the clean inspect /oil and replace worn parts.sounds like you wont see much wear because it stops after[gets warm]so may get buy with oil/cleaning Ps unplug before working
Dec 31, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Driver Belt
just remove back cover ..install belt on small motor pulley first then work around drum pulley while turning large pulley try spinning by hand first to verify belt is tracking in center or close to center of large pulley
Jul 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
Marvin
Marvin
