You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
Motors humming are indicative of the start / run capacitor failing or the motor shaft is sticking. Get the the motor and see if it spins freely? It may need lubrication or the capacitor replacing. The purpose of the capacitor is to give the motor a jolt to get it going.
You have a short. This is either from a bad cable or a faulty price of gear.
to find the problem do you want to isolate pieces of the system. Turn on just your speakers (if they're powered) or amps (if the speakers are not powered). With the mixer off, if you were getting a pause the short exists after the mixer. No buzz? Great! Turn the amps or speakers off to prevent popping. Turn on the mixer, and then turn on the speakers or amps. If you have a bus now with all channels on the mixer down it is likely your mixer. If there is no buzz, Bring the channels up one at a time. Once you find the buzz, turn the channel back down and plug unknown working microphone and cable into its channel. If the Mike buzzes when you bring the channel up it's the channel on the mixer. If it does not then the issue exists before the mixer. This is most likely and also the least expensive to resolve. Check the snake if you have one and all cables in line in a similar fashion. Most likely a snake channel has failed, you have a bad cable plugged in the snake Or you have a bad DI box or mic plugged in.
Yeah they do need to be replaced from time to time. Make sure you get a water test kit and check your water hardness. You may need a whole home water filter if it is outside of normal ranges. A pretty easy DIY project and relatively inexpensive at the big box stores
Hello, sounds likemyou have either a bad humidistat or solenoid valve, disconnect the wires from the humidistat if this turns off the humidifier than replace the humidistat. If not the solenid valve will need to be replaced,
Don't know why so much water. May be able to adjust by turning down valve tap. Turn unit on and you should be able to hear water pressure decrease. Make sure damper in 6" pipe is open so humidified air will get through system. When very cold humidities are lower. Also must hum. mfgs. suggest connecting with hot water instead of cold (vaporizes faster) don't know which you have
If you can easily get to motor I would unplug unit and check motor to see if it turns freely. If it does I would plug the unit back in and see if the humming noise is coming from motor. Ifyou decide that the motor is the source of the noise and you can do so safely spin the fan and see if it will try to run, If it does I would unplug unit and give fan motor and blades a thorough cleaning. Clean any hair,lint or dust from aaround motor shaft. A small motor like these does not take much to slow or stop them. Plug it back in and try it. If it stiil does not work I would replace the motor. Hope this helps. Thanks
Make shure the 24 volts is hooked up to power that is only powered up when the blower is running. Some furnaces have a HUM terrminal on control (make shure the HUM is 24 volts some are 120 volts then you must use the transformer supplied with the AP 600). You can use a RP # 50 relay that senses current only when the furnace motor is running on the heating speed. Hope this helps
