Question about Dryers
Does it have a pilot light? the flame does not come on anymore
It is a gas dryer
does it have a pilot light?
  • 5,911 Answers
Gas dryers do not have a pilot light. They usually use a glow-bar type igniter which is located on the burner assembly. It usually takes about 30-90 seconds for the gas to ignite on these dryers. The reason for the delay is because the burner assembly is equipped with a gas safety valve that prevents free flowing gas from entering the appliance cabinet without ignition. The following link explains:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
The link is for a gas range, but the principle of operation and the type of igniters used is still the same. The igniter is the more common failure when it comes to gas ignition problems. More than likely you have an igniter that has become weak and needs to be replaced. Just because an igniter glows, does not mean it is good. It should only take about 90 seconds or less for the oven to ignite. If you've been experiencing longer ignition times, this could be the case.
Read through the link provided and let me know if you have any questions. Please post a complete brand name and model number as this will help in providing directions on how to access the dryer interior. I hope this helps you solve your problem.
Posted on Jun 21, 2009
Trying to light a new gas dryer. was unaware it was gas lol
Gas appliances normally require a pilot flame. This flame heats a thermocouple which operates the main gas valve when you want heat. The pilot flame may be out. Gas valves have a start-up process which normally requires you to press and hold the pilot flame button for up to 30 seconds (until the thermocouple heats up).
Your appliance will have been delivered with a user's guide in which you will find the pilot lighting procedure...OR...there may be a guide adjacent to the gas valve.
Apr 12, 2013 | Dryers
I think my pilot light went out, but I need to know how to locate it
Dryers do NOT use a standing pilot lite ..When the unit is turned on and heat is commanded on the gas valve opens and an igniter lite's the gas , then their is a flame sensor to see the flame from the burning gas if no flame is present it shuts the gas back off.. So if you have a no heat concern with your dryer it will be either the igniter, gas coil's or the flame sensor
Jan 03, 2011 | Dryers
GAS LG DRYER TUMBLES BUT DOES NOT HEAT, WHAT COULD BE WRONG? CHECKED THE BREAKER AND GAS LINE, BOTH ARE ON AND GOOD.
Pilot light (flame) may have gone out..Dont know if you are on gas bottle or mains,if on bottle make sure not empty..most likely Pilot Light (flame).cheers
May 28, 2010 | LG DLG5932W Gas Dryer
Old maytag gas dryer. Does not heat anymore, gas
Maytag dryer series 05. How do I light the pilot?
Apr 04, 2010 | Maytag Dryers
Dryer goes on but does not heat up no flame
No flame indicates that this is a gas dryer?
If so, there has to be either a pilot light, or an ignitor. If it has a pilot light, make sure that it is lit. If it isn't, the gas will not flow. The sensing bulb above the pilot light must be hot before it will allow gas to flow.
Aug 14, 2009 | Kenmore Dryers
Intermittant flame, ignitor function is good, all other functions are as designed,timer ,tumble etc.
Hi
The pilot light flame would sometimes get very small and keep going out. This was usually because the pilot orifice was getting dirty and was partly plugged. The pilot orifice must be cleaned out when the flame becomes too small to light the main burner. You can blow air through the pilot assembly to help clean it out, don't use something metal in the pilot orifice hole or you risk enlarging the pilot gas feed hole and the pilot light may be too BIG. If your pilot flame keeps "going out", chances are you will need to replace the pilot latch do make sure the vent hood flapper is closing ok and no outside air blowing in is effecting the pilot flame.
This is a thermocouple that sensed the heat from the pilot flame and kept a small amount of gas flowing to allow the pilot light to stay lit. If you followed the instructions ( usually found inside the small access door on the front bottom ) on how to re-lite your pilot when it goes out and the flame will not stay on, replace the pilot latch assembly.
Please accept the solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | Whirlpool GGQ8831L Gas Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Whirlpool gas dryer heat goes on then off then on again
should have electronic igniter that light gas after turned on.
Jan 03, 2009 | Kenmore 73952 Gas Dryer
No hot air
If you have a pilot light (small flame) you can try to re-light it by turning the knob on the gas valve to the pilot position and pushing the knob down while lighting the pilot, you may have to hold the knob down for up to 30 seconds before releasing it. The pilot should stay lit and then turn the knob to the on position. If the pilot will not stay lit or the main burner will not light it could be the gas valve or the temperature sensor.
Jun 11, 2008 | Dryers
Gas dryer
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Jan 24, 2008 | Dryers
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
83 people viewed this question
Top Dryers Experts
Marvin
Marvin
