Question about GE Refrigerators
We have model TBX25PASLRAA. we keep seeing water on the bottom of the fridge. I just checked and seems to be some ice like it's freezing. No signs of water leaking down from the freezer. Any suggestions?
    Novelist:
  • 103 Answers
Hi there: Most likely it is a problem with the defrost drain. Common in GE's. Luckilly not expensive to fix. The water is guided down to the bottom of the refrigerator to a pan above the coils to evaporate the water. If it gets clogged the water will ususally pool under the crispers. The defrost water just isn't going where it should. Some older GE's directed the water to a trough benind the crispers, then through a hole (like a shallow funnel) to the pan. Lood for this hole under the crispers and clean it out. With a pipe cleaner or a cup of warm water and bleach. If there is no hole there continue to the next pary. I looked at your model on line but the parts diagrams weren't clear as to where the tube goes(inside or outside of fridge,). This is why I'm giving you two parts. It is also possible that the defrost tube runs down the back of the refrigerator. In this case empty the freezer and look in the back for the same hole in the back of the shallow pan. This link might help you to locate it. Then use the warm clorox water or a pipe cleaner to clean out the tube. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=TBX25PASLRAA&productCategoryId=0166000&brandId=0432&modelName=TOP-MOUNT-REFRIGERATOR&diagramPageId=00005&componentDescription=COMPARTMENT .
I hope this helps, Jeff
Posted on Jun 21, 2009
Ge profile fridge model PSC 25MSW/PCF 25 MG W PSH25MGW freezer works fone but fridge too warm.
Check to see if you can see any ice building up in the damper between the frig and freezer.
Oct 23, 2014 | Refrigerators
I have an Gallery series Fridgidaire side by side fridge, model number GLHS68EJSB0... the line to the water filter keeps freezing and unable to depense water... we have the setting on the fridge set to the...
We have the exact same problem. But ours is in a vacation home so we have to keep the water turned off all the time. It seems something in the ice line freezes when the fridge is empty. Then, no ice, no water. When we turn the water back on, after a few days of having food in the fridge, it seems to make everything melt and flood the tray then leak out onto the floor all day and night. The fridge temp goes down to 12 degrees when the fridge side is empty. It seems to stabilize when there are items inside. We put several gallons of water inside instead of leaving it empty and it helps with the temp but not with the leaking. We have had service come out several times and they just said, "don't leave it empty and turn off the water when you leave." What good is that? I don't have water or ice for the weekend when I go up to the house! OR I clean up floods the entire time!! Now it's out of warranty. Now that I see it happens to people in their main house, I would just say NEVER EVER EVER BUY FRIGIDAIRE AGAIN!
Sep 24, 2011 | Frigidaire FRS3R5EMB Side by Side...
There isnt any water getting thru to the icemaker. i changed the watervalve and still no water i cannot locate the water filter even tho i removed the bottom grill, water is still getting to the water...
if you put a new water valve on the fridge then you either have a bad ice maker or the line is frozen where the water fills the ice maker,a bad water valve will make the line freeze,water keeps dripping through the valve and freezes the fill line behind the ice maker cup,you can remove the ice maker and check the fill line,if it's frozen get a hair dryer,shut down the fridge or unplug it and blow the hot air into the fill line until the ice melts,then get a piece of wire and after you reinstall the ice maker pop off the cover to the ice maker and jump it out with the wire,stick it in the t and h for 15 seconds and pull it out,if the ice maker is good it will start turning and when the arms get at like 11 oclock it should fill,also you can jump out the fill valve from the ice maker,stick it in v and L and if water fills the ice maker you know you have a bad ice maker if the fill line isn't frozen.hope this helps.next time you need help send the model number,on your machine look in the fridge section on the right hand wall up near the ceiling to find it,if it's older look down near the bottom hinge on the fridge door and you'll see a tag with the model number.good luck
Sep 12, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Model 10658143801 not making ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | Kenmore Refrigerators
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
imufo2
Leo Ponder
Jul 26, 2011 | General Refrigerators
I have a sub zero model 650 refridgerator. It is making some ice then it seems as though the water keeps dripping and it freezes up the shelves. Its like the water doesn't shut off when its suppose to...
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Refrigerators
Water reservoir in bottom back of frig keeps freezing up.
Too cold in fridge if it is freezing is your milk or other items freezing. Check temp in fridge with a good thermometer.
Nov 13, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Whirlpool refrigerator Model Number ET1FTTXKQ03 Keeps freezing
common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 10, 2008 | Whirlpool ET9FHTXMQ Top Freezer...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
