I have just put a wash on but when it had finished I noticed the wash was soaking wet and there was still water in the bottom of the machine? would this be a filter problem? if so how could i fix this? Hotpoint Aquarius WMA40S
    New Friend:
  • 70 Answers
Yes there is some filter problem call to service center and repair it please.
Posted on Jun 21, 2009
Machine not washing and when finish washing still soaking wet
water not pumping out =faulty water pump kick in
wash cycles not working
could be faulty control board or timer
Apr 16, 2017 | Washing Machines
Should I be able to see water in the tub of my Kenmore 796.4027 washer?
different machine
the water spurts are operating as the drum rotates so that the clothes are evenly wet before the wash process begins
could be designed to use less water than previous models
make sure that the drain hose is at the correct level or all of the water will drain out
talk with a service agent and read the user manual for the operations and what can be expected
Apr 17, 2017 | Kenmore Washing Machines
I am very unhappy with this machine and sorry I bought it! It uses so little water that sometimes when I take the clothes out after it is finished washing I can see dry spots on the clothes that never even...
How about putting the clothes in and pouring water over them with a jug before the washer starts its program ?.
It could also be that the water level switch is out of tolerance and needs replacing
Most machines have a pre-wash cycle as well
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag top loader on final spin cycle leaves the clothes soaked
how much water is in the bottom of the tub and is it louder than normal if so could be small droplets of water leaking from tub seal if not the pump is restricted by something and req replacement
Aug 20, 2009 | Maytag Washing Machines
I have run the machine on a daily wash
It sounds like your water discharge pump is either clogged or not working to full capacity. You can check this by looking at or feeling your discharge hose during drain and spin to see if the water is actually draing fast or just dribblig. If this is the problem then call a teck or change the pump yourself. If you do it yourself please unplug your unit before working on it. I hope this helps you.
Nov 20, 2008 | Indesit W 123 Front Load Washer
When cyle is finish clothes are still soaking wet
Sounds like a slow drain. Recheck the drain hose if it looks ok get a bucket to put the hose in to see how fast it comes out. If it comes out slow the drain pump impellor may be broken.
Apr 17, 2008 | Frigidaire GLWS1233A Top Load Washer
Not draining after cycle
try checking the filture on the front at the bottom of the machine they some times get full of muck
Jan 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Bosch max wfl2000 washing machine
Just been through this with our Bosch Maxx, problem was the pump discharge pipe was blocked with soap deposits. I also removed the large black rubber pipe from the drum/pump and cleaned this out as well.
All working fine now.
SteveN
Sep 08, 2007 | Washing Machines
Water leaking from wash machine
It is probably a seal that is on or near the bottom of the tub. Dirt and grim wears at this seal over time. The leak is slow so it is hard to visually see.
Dec 09, 2006 | Frigidaire MWS939Z Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
