Question about Dell PowerEdge 1300 Server
Windows 2008 and Dell PowerEdge 1300
Would WIndows 2008 install on PowerEdge 1300?
  • 130 Answers
Yes
Posted on Jun 21, 2009
How can i istall windows server 2000 on Dell Poweredge T300
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Jan 26, 2015 | Dell PowerEdge T300 Server
How can I find the Windows Server 2008 driver files for the Adaptec CERC SATA1.5/6ch?
OK, EZPZ.
These drivers will install when you first start installing windows 2008 server. You'll see a option that says: Hit F4 for any further drivers needed for windows to install. I think it's F4. You can place these drivers on a thumb drive OR a CD - you must extract the files on to a thumb drive. At the very start of the windows install you'll see the option for additional drivers.
First screen - Success
SCSI - Yes, that is correct. Correct, but This isn't a SCSI controller
If you choose the SCSI driver from Dell, on the disk, you won't get...
This screen. This screen means that windows could not find any driver for your drive and there for, you must start over - Same steps.
But make sure you choose the correct driver - you might have to try a few that are in the list.
Greatest of luck - EZPZ
Have a great night..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Aug 11, 2014 | Dell PowerEdge SC1420 Dual Xeon 3.2GHz 2GB...
Unable to install windows 2008 r2
too old hardware ?, more memory or harddrive size
Apr 09, 2014 | Dell PowerEdge 1800 Server
How to install a dvd drive in a dell poweredge 1300. p3/500mhz/512ram
hi there, switch on your pc until windows appear,open your DVD CD room by pressing the button in front of dvd cd room on your pc.wait until the insttaller application appear the follow the instruction,and have it install then restart your computer to take effect.you can check this on device manager.select dvd device the left click and go to properties and check the driver.,sometime it failed to install due to compatibilty in case this happen find the driver compatible to your dvd.just type on internet, in search the brand of your dvd and include free driver.select the most applicabe.have a nice day.fix my rate,thanks a lot.
May 10, 2010 | Computers & Internet
I turned it on and now it won't even start up it gets stuck on microsoft windows xp start up screen, what do I do?
See if you cant get it to start up in safe mode and run a check disk.
http://support.microsoft.com/kb/315265
If you cant get into safe mode, I hope you have a windows xp installation disk to run it from the CD: http://kb.wisc.edu/helpdesk/page.php?id=5097
Apr 08, 2010 | Dell PowerEdge 1300 Server
How to install hyper v on dell 2650. Can Windows 2008 with hyper v be installed on a Dell 2650?
Yes, Server 2008 will install on the 2650 as long as you make sure you have enough RAM and hard drive space. Once you have Server 08 installed, you will have a to-do list to help with setting up hyper-v.
Good Luck
C2Solutions
Feb 26, 2010 | Dell PowerEdge 2650 Server
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
Windows 2008 Server not able to installed (with RAID)
tripathi_g
The CD may not be the operating system CD. What is the full text on the disk and what are you trying to do.
Issken
Mar 23, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
Beeping PowerEdge 1300
When a Dell server beeps in every 3-5 second that mean it comes from Raid controller.
Dell calls PERC Controller.
It usually reason of a disk failure.
Install open manage server administrator on your server.
See which disks are failed ?
Try to run Power edge diagnostics on the failed disk.
If it passes the test reseat the disk.
if it fails disk has to be replaced with a new one.
If passes the quick test, reseat the disk and update disk + perc firmware and driver to the latest level. that will solve the problem!!
99% beeping comes from perc controller because of a failed HDD
cheers
Aug 18, 2008 | Dell PowerEdge 1300 Server
Dell PowerEdge 1300 Server Logo
143 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
