Question about Sigma AF 28-200 Lens
Broken gear inside lens
The problem is a broken plastic gear inside ,its a matter of finding one and simpe disaembly to replace the gear,my lens has the same problem,id like to know where i cxan get parts for sigma in australia,the lens CAN be fixed,I have done same to nikkor AF lenes
    New Friend:
  • 117 Answers
Send me a email to garyphm@hotmail.com
Posted on Jan 11, 2010
Gh700 grasshog trimmer - round plastic gear drive broke in half - can I get a replacement or even a metal gear?
Same problem; GH700 with a stripped gear, inside the casing.
I wish places with replacement parts sell uncommonly broken pieces... I didn't have an account for commenting a request in that site.
If someone asked them, it could be available in a matter of time.
Black and Decker GH700 14 GrassHog Trimmer Edger Parts
Sep 01, 2011 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Camera lens can't focus
The lens is driven by small chips and gears. Usually, the lens will get jammed when it tries to go out, and something will give, usually a plastic gear. When that happens, you have to totally disassemble the unit to replace it, and it's a heck of a job. The only other things you can try is to blow with compressed air, and hope it's just some dust impeding the proper location of the lens. You can also try to pull on the lens, as it comes out, hoping to reseat the gears and such. However, if a gear tooth is broken off or some other part is broken, it has to be replaced. In that case, better to buy a new one, they're coming down in price all the time. Good luck!
Mar 14, 2010 | Olympus FE-280 Digital Camera
Lens error: camara has broken gears in lens assembly
Hi kevin3738 and a_nester
ok for kevin3738,
im thinking that since you said your lens doesn't extend all the way out that maybe you might have cracked a gear in the lens housing, the mechanism to extend that is located when you open the camera and take off the front face plate, on the right side of the lens housing **silver part** you see a black plastic casing attached to a motor on top and screws in it, that is what moves the lens housing in and out, in that are a few gears, i think 4 of them lat move the housing, 3 small ones and one big one that reaches down to the bottom of the housing, they are interchangable but im not sure as to where you could find a gear to replace the broken or cracked one,
And for a_nester
im gonna take a guess at what exactly the problem is on your camera, and it might be the lens autofocus
in that case you can look here
http://www.fixya.com/support/t780884-lens
or
http://www.fixya.com/support/t805636-cameras_lens_messed_up
Jul 01, 2008 | Casio Exilim EX-Z77 Digital Camera
Problem with fe-210
Lens gears are probably broken off, or other problem with lens. Will need to replace lens, or may possibly be repaired. I've repaired a few lenses with gears broken off, by replacing broken off posts with similar size plastic pieces(drilled holes and super glued in place, being very careful). Still working months after repaired. Olympus repair shops can replace anything needed, but at a HIGH price; sometimes cheaper to replace camera than to have them work on it.
Jun 08, 2008 | Olympus FE-210 Digital Camera
Used FE-170 hardly powering on.
The lens need to be replaced or repaired. It is not fully extending. It may be that one or more of the plastic gears or plastic rods that hold the gears in place, are broken. I repaired two plastic rods in my lens, by drilling holes for new plastic rods,(I cut plastic rods from a plastic toilet bowl chain!!! It fit inside the gears perfectly), and super glue the rods in place. Replaced gears, put camera back together and BAM in worked! Nothing like a perfectly working refurbished rig job. Camera takes great pictures to this day.
May 10, 2008 | Olympus FE-170 Digital Camera
FE 170 OLYMPUS digital camera
Nov 27, 2007 | Olympus FE-170 Digital Camera
CAMERA WON'T TAKE PICTURES?
I took the camera in my right hand and wacked it against my left hand.
It has been working for 10 months now and still taking great pictures.
Jul 10, 2007 | Olympus FE-170 Digital Camera
Lens motor
check the gear box, maybe one of them is broken. Look carefully every gear this is a very common problem in this camera
May 03, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
My Optio won't stay powered on.
This is probably due to a broken sensor tab inside the lens, or a failed sensor. When the lens reaches the end of its travel a small plastic tab will pass between the ends of a C shaped sensor and let the camera know the lens has reached the end of its travel. You are not hearing a safety device, you are hearing the gears actually slipping. Don't let it do that too much or you will turn one problem into two problems quite quickly. If you cant find the broken part it will require professional repair. I would advise against taking the lens assembly apart. They are extremely hard to get back together and you very well may end up with a junk camera. David Millier Advance Camera Repair
Feb 11, 2007 | Pentax Optio 430RS Digital Camera
Sigma AF 28-200 Lens Logo
377 people viewed this question
Top Sigma Cameras Experts
M_Butkus
Steve
bhargav
Are you a Sigma Camera Expert? Answer questions, earn points and help others
