Question about Music
I have a triton le 61 and iI cant get it to save any sequences. everytime i try to save one it says ''error in writing to media. what should i do
    Scholar:
  • 109 Answers
Sounds to me like something corrupted on the memory module. May want to try another compatible memory card.
Posted on Jun 21, 2009
Hello everyone, you are my last hope. Here is my story I have a Triton Le bought in Mexico in 2005, it has the American AC/AC power supply cable. I moved to Europe and there I bought a 240V INPUT (9V...
I have been trying to find a schematic, however the damage should be limited in the unit.
Since there is only 9VAC input, we know that it has to go through a rectifier and a filter capacitor and then likely a regulator. I doubt the problem goes beyond the regulator.
The screen light MAY be independent of the logic power in the unit, the LED's will NOT be independent.
The voltage rating of the fuse is NOT a problem.
You likely blew out the rectifiers as a start. They may be individual diodes or a small module with four diodes inside.
The diodes SHOULD have survived but check them with an ohmmeter on the diode range. The Filter cap may be destroyed, and alsothe regulator which is likely a three terminal one like a 7805.
Aug 11, 2010 | Korg Pa800 Synthesizer
How do I play the O1WFD sequencer through the Triton Pro X??
Here is a link to a site with all the info you need:http://forum.recordingreview.com/f18/midi-troubleshooting-101-a-5208/ You will need to join which is free and well worth the time. I also recommend downloading the free book Killer Home Recording Setting UP.
May 16, 2010 | Music
I own a korg triton music workstation sampler and when I create a sequence using the 16 tracks and I want to make a song using a que list all of my inserted effects on all the instruments do not work when...
you need to ensure that you have recorded the midi command to select each effect and level of that effect. this can be done in the midifile. you need to start record and very quickly at the start of the song you need to select the effect and set the level, whilst in record. this should write the setting into the song. you can check this if you use an external sequencer.
Dec 13, 2009 | Music
Broken Triton push button
I am not familiar with your exact model, but if the plastic "hinge" for the button has broken, it is possible to "fix" it. This is not a DIY repair though. Can you tell me where you are located so I can perhaps suggest a repair location?
Thanks,
Dan
Nov 04, 2009 | Music
Can I plug my American bought triton in European standard electricity Korg 61 key Triton
Only if it has a switch that changes over to 220. I beleave, if not ten you will have to get a power inverter for the power difference and plugs for the different styles that they have over in europe. I hope this helps.
Aug 15, 2009 | Music
Korg triton extrem 61
I don't know what problem you have but try this site. http://www.korguksupport.co.uk/sitemap.cfm I hope the info you need is there. Also try googling the synthzone.
Jul 30, 2009 | Korg Music
A ''static'' sound coming from ALL outputs of Korg Triton
try cleaning ALL the contacts involved with Caig DeOxit (D5, S5. F6, G5, etc.) products*, they work very well. e.g.; cables, inputs, outputs, and (if you're confident) all the contact points "under the hood". this static you speak of sounds like less than stellar contact points and can addressed at home if you've the motivation to DIY.
* amazon.com/D5S6-Contact-Cleaner-F5S-H6-FaderLube/dp/B00HNV7WI2?SubscriptionId=AKIAILSHYYTFIVPWUY6Q&tag=duckduckgo-d-20&linkCode=xm2&camp=2025&creative=165953&creativeASIN=B00HNV7WI2
Mar 31, 2017 | Music
Music Logo
52 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
