Question about Viking VGSC366-6B Gas Kitchen Range
Broil is not working on my Viking Range
Hey i have Viking Range with 6 burners and a grill in the middle. Ive recently had a problem with my broil, it doesnt work. I Usually wait for a min for the top metal to light up and start working but it just doesnt work. But when i turn the knob on Bake it works perfectly fine. So basically my broil doesnt work in any circumstances. If you may please email me with a solution. Thank You ( model # vgic4876gss)
5 Suggested Answers
  • 521 Answers
SOURCE: Oven quit, bake not working, replaced thermostat, now broil works, still no bake
Your problem may be the bake relay on the clock or wiring.try changing that
Posted on Aug 12, 2008
SOURCE: viking broil igniter does not
There are three separate igniters, one starts the broiler and the other two are bake ingnitors left and right.
So the bake circuits ignitors work and the broil doesn't
Replace the ignitor
The part number for all of them is PB040001
Posted on Mar 04, 2009
  • 23 Answers
SOURCE: Viking Dual Fuel 6 Burner 48" OVEN DOES NOT HEAT
I hate self clean functions - If you think about it - you should too. These ranges are equipped with electronic components and running self clean at 950 degrees will more than likely burn something out. A lot of complaints are because of the self clean. It's not worth it to self clean than to clean it yourself. And 200 dollars is a great price for something like this if it includes parts and labor. Good luck.
Posted on Sep 18, 2009
  • 30 Answers
SOURCE: replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Posted on Jul 02, 2010
Repairing the burners on a char broil commercial grill
well the burners may have fell of the injectors and the gas is missing the burners try re fitting the burners back on , if not you may have a broken gas line .
Jun 08, 2012 | Char-Broil Grilling
I need a new burner for my Broilking 531/33GBC and the grid the coals rest on. Pity all the new BQs are all just tin.
Onward Manufacturing, the company who makes Broil King grills, doesn't make a gas grill that uses coals above the burners. I have been a Broil King Dealer since 2005, I haven't seen one yet. Are you certain you have a "Broil King Grill?" As the Model Number 531/33GBC, you listed, doesn't show up in my data base for Broil King. Perhaps you have a Broilmate grill? Which is made by a different company.
Please advise. Thanks
Jun 26, 2011 | Grilling
Have model 463728504 char-broil withno manual and I do not knowhow toturn side burner on
Here's a link to your Owners Manual, that you can download and print for future reference. Pay particular attention to Page # 8 (lighting the burners).
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/7001189_463453306_english_37f8ef8b-0_.pdf
Happy Grilling!!
Apr 10, 2011 | Char-Broil Advantage 463453306
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
I have a char-broil Grill where the ignition wire came loose and do not know it came from
it come sfrom the ignitor on the burner or off the sparker /ignition button
May 20, 2010 | Char-Broil CharBroil 4637318 Grill
Use of Charcoal or Lava Rocks in the Char Broil Patio Caddie?
LP grills are designed to use lava rock ONLY. Charcoal will clog the burners.
May 16, 2010 | Char-Broil Patio Caddie 4654870 (LP) Grill
My grill burners burn unevenly and usually too high. Adjustment?
If this is a natural gas grill, check to see if it has a regulator on the gas line. If it does not, you can install a regulator to reduce the gas flow.
Dec 01, 2009 | Char-Broil Commercial Stainless Steel...
I have a char-broil 3 burner grill that is about 6 years old. It has 3 circular burners. The amount of gas now getting to the burners is equivalent to low even when the dials are on high. Do I have a...
most likely burner problem try removing burners (they generally just lift out or held by 1 or 2 screws) clean the sides of the burners with wire brush most likely then orifices on burners are clogged hope that works for you
Aug 23, 2008 | Char-Broil CharBroil 4637318 Grill
Viking VGSC366-6B Gas Kitchen Range Logo
81 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
