Question about Garden
How do I fix the pull rope on a push mower? - Garden
    Problem Solver:
  • 14 Answers
Did the rope break, or is it hung up? if it broke, you need to take off recoil cover and manually rewind spring until existing rope can be pulled through the cover to compress spring. use the same size of rope and feed new rope through hole with spring about fully wound. If hung up, you need to clean the cover that is on of the crank case top. Do not use oil because it will make the ball bearings seize up. is it a briggs or other? I explained procedures for a briggs.
Posted on Jun 24, 2009
  • 82 Answers
SOURCE: Lawn mower died. Pull rope locked up
remove the spark plug and try to pull the rope. Sometimes the coil can get loose and wedge against the flywheel. if that's not the problem then pour a little oile in the spark plug hole, let it set a bit, if it still won't turn over then you have an internal engine problems. Not very common but it can happen
Posted on May 09, 2009
  • 420 Answers
SOURCE: ROPE ON MOWER WON'T PULL OUT
I agree, it sounds like the mower is fouled with foliage at the blade. Pull off the spark plug wire and tilt the mower on its side opposite of the carburetor, check the underside of the mower for impacted grass clippings.
Posted on May 14, 2009
SOURCE: Pull rope seems to be locked up...won't pull
make sure you can turn the blade by hand, make sure grass isn't stopping the blade after that make sure the break cable isn't bad, sometime's the cable don't disengage the break from the flywheel. Hope this works.
Posted on May 24, 2009
rburroak
  • 14 Answers
SOURCE: Pull rope snapped on my Yard Machines 4hp 22in push mower
There should be 3 -3/8 or 7/16" bolts on the side of mower (where the spark plug is, there should be one) the other two will be just opposit of the two. Remove bolts and housing should be free.You might to remove any cables to free up any slack.
Posted on Jun 19, 2009
  • 130 Answers
SOURCE: pull rope came out of Yardman push mower
you should have three bolts one in the front one on each side at back
Posted on Jul 20, 2009
How do i fix a broken pull cord
take off any plastic covers, take off pull rope housing, take out old pull rope tie a knot at the end of new rope to be installed. wind rope housing counter clock ways to tighten the spring up. when it stops turning back of one turn. line up the hole on the plastic wheel with the hole on the side of housing and push new rope through. pull rope till the knot seats in the knot hole. put rope handle on and the covers. there are many videos that will show you how to do this on you tube. good luck.
Feb 05, 2016 | Garden
3hp briggs and stratton push mower/pull rope does not engage and turn over engine
if its the old 3hp engine then they have a starter clutch fixed to the crank shaft. they have ball bearings inside and can sometimes get stuck or the gears can wear out. you would need a special tool to remove the starter clutch but you can prise off the top plate on the clutch to inspect the internal workings
Sep 07, 2014 | Garden
I have a Yard Man self propelled push mower the pull rope broke I replaced the rope but now it won't recoil . Please help me find out what is wrong. Thx.
OK first remove recoil unit off motor, Whats the pull start.
Next pull the rope all the way out.Watch the direction the rope pulling is turning. When the rope is pulled as far it can be put something in to hold pulley where it is. Cut off rope knot and remove rope.Then hold pulley remove what is holding it from moving then continue turning rope pulley in same direction until it stops.Then turn opposite way to line up hole in pulley and hole in metal shield and block. Then slide rope through holes and tie knot tight. Release pulley slowly and rope is going to retract just like new...
Aug 04, 2014 | Garden
I just set up the mtd push mower and can't pull out the starter rope?
is the handle pulling the cable to release the engine brake ?
May 13, 2012 | Garden
I have a Yard Machine Lawn mower by MTD it has a briggs and stratton engine. The pull cord pulls, to easily I might add, but will not start the lawn mower. It doesn't seem to engage the motor. What might...
If you think the rope pulls too easily the engine may not have enough compression. Consider doing a compression test or a leak-down test on the cylinder.
Oct 23, 2010 | Mtd 22" Yard Machine Push Mower
I can't pull the starter rope more than a few inches. Just purchased the mower. Its a craftsman push mower
Try taking the spark plug out and pulling it. If you have a bunch of gas, oil, or water come out, and the engine turns over, you will have your problem. If you have stuff in there, you will want to pull the starter rope a bunch of times to try to push it all out, and then dry off the spark plug, put it back in, and give it a go. You may have to leave the plug out for while to let the cylinder dry out.
May 31, 2010 | Craftsman 675 Torque 190 cc 21" Push Lawn...
How to replace coil string
This is best done with two people. Remove cover, place down so you are viewing the rope pulley. Remove all old rope. Measure 8 foot of new rope. line up pulley rope hole with rope opening in cover. Wind rope pulley 6 turns. Push new rope thru both rope openings, one in pulley and one in cover. Pull rope thru pulley and cover. Tie knot in pulley end of rope, Slowely release rope so it rewinds onto pulley. Install hope handle, your done. was'nt that easy? You will have extra rope, this is needed to go from engine to handle support on your mower handle.
May 28, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
Lawn mower pull cord
This works best with two people. Remove cover and pull cord will be inside cover. If your handle on pull cord is attatched to a metal ring up on the handle, you will need 8 foot of new pull cord.
With all the old cord removed, wind cord pulley 6 revolunations, now, have someone hold the pulley, while you string the new cord thru pulley and out the cord hole on cover. Be sure to put a knot on the end going thru pulley. Draw cord all the way thru and out of the cover. Attatch the handle and let it rewind. You will have extra cord, this will be used up going from engine up the handle. I hope this helps
May 04, 2010 | Mtd 22" Yard Machine Push Mower
434 champion starter cable
If this is a normal push mower with a pull start remove the starter housing and inside you wil see the pulley that the rope is contained in. Get the pulley out and remove the old rope. Push the new rope in through a hole and double knot it. Reinstall the pulley and you should see a slot in the pulley that you can pull rope out to wind the spring.With the handle also on you should be able to wind the spring up to a desired tension. Hope this will help a bit. Donnyb60
Mar 17, 2009 | Garden
Garden Logo
316 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
