Question about SanDisk Sansa e260 MP3 Player
16gb Sansa player that recharges and plays for only 3-4 hours
I recently recharged my audio player and was surprised when it played for only 3-4 hours. It had been a while since I used the player and after the first recharge and 3-4 hour play back the problem of short replay life span was repeated. Is there any way to regain the 16-20 hour music play back time I originally had with this player. This player was purchased brand new and is only a little over a year old.
    Problem Solver:
  • 16 Answers
Let your battery run out by leaving you mp3 player play as long as it can....then open up the back of the mp3 player take out the battery and put the battery a freezer for an out or 2 then let it sit out for a day then put it back in the sansa and recharge it and it should either fix it or help add more life span to the charge
Posted on Jun 22, 2009
  • tj sobie
    tj sobie Jun 22, 2009
    let your battery run out by leaving you mp3 player play as long as it can....then open up the back of the mp3 player take out the battery and put the battery a freezer for an out or 2 then let it sit out for a day then put it back in the sansa and recharge it and it should either fix it or help add more life span to the charge
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
How to recharge the Sansa e200
Play songs then on one of the tabs it says Sync then click the arrow under it (you have to move your mouse around the tab to find it) then click Sync Now Playing, and wait for it to finish.
Jun 21, 2009 | SanDisk Sansa e200 MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Battery Low Message - Won't recharge
did u try connecting it to your computer like i do mine
Jan 24, 2009 | SanDisk Sansa e250 MP3 Player
Nothing happens when ON switch is pressed.
Have you tried recharging the MP3 player? I too have a Sansa Clip which I play in the car so I don't often see the "battery low' message, but when I recharge it the MP3 player works again. I understand it takes longer to recharge from the computer so I bought a recharger I plug into the wall.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
I have a 1GB mp3 clip player. It was playing for about an hour. Then it stop playing. It does not have any batteries. How do I re-charge
If you are referring to the Sansa Clip, then you must connect the mp3 player to the computer using the USB cord - make sure that your computer has a USB 2.0 port, or it may not have enough juice to recharge the player.
Mar 07, 2008 | Audio Players & Recorders
Prombles Recharging Battery
Try upgrading the firmware of the player. If it still discharges quickly it may be the battery contact POP and have the battery replaced.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
Cannot charge or copy music onto the sansa e270
You might not have the battery "seated" correctly. Try removing and replacing the battery.
Sep 04, 2007 | SanDisk Sansa e270 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
