Question about Haier Mechanical Air Conditioner HWF05XC7
Unit on but no cool air out
My newly installed 5200 BTU unit will turn on with the fan running but no cool air comes out. Please help.
    President:
  • 1,515 Answers
Hi, so what is happening is the compressor is not running. Being a new unit, I would say that you have a factory defective part that starts the cooling cycle of this unit that is not coming on when it calls for cooling. Just because it is new, does not mean you can't have a problem. I have seen on so many new units from commercial and residential roof top units that have never even been started, come from the factory miss - wired, faulty compressors, you just couldn't imagine what I have found in my 33 years working on these units!! Yes, all that is coming on is the blower motor on this unit. It could be many things causing this problem. Did you install it your self? If so, was the unit picked up by you or delivered and installed by a company? The reason I am asking this is, if the unit was layed on its side at any time during transporting to site, this will cause the compressor oil to drain from its crank case and mix with the refrigerant and cause compressor failure instantly. I am sure you no that when moving a refrigerator that you never lay it down that it must be upright? This is why. I don't know if this is the case. More then likely, it is a factory defect.Some of these units will have a built in time delay for the compressor not to start up for up to 3 to 5 minutes. But if you have been running it for longer then this, thats not the problem. Make sure you have the control set for cool and not fan only. This happens sometimes on accident. If it was installed by someone else, call them out to look it over and trouble shoot it, or install another one if it is new! I believe this might be a portable free standing unit? If so, and like I said before, if it was not upright at any time, this will ruin compressor. If it is a portable unit, take it back and exchange it. There are to many things that can cause this, and you would have to take unit apart to trouble - shoot these controls. Best to be done by a pro. Please, take it back for exchange. Please let me know what is up, keep me posted.
Sincerely,
Shastalaker7
Posted on Jan 15, 2010
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
Newly installed, the outside unit will not run but the fan on inside will run
checkto see if your getting 24voltsat the condensers control wire and chech for power voltage
Jan 08, 2013 | Ramsond 12,500 BTU 1 Ton Ductless Mini...
Simplicity 5200 btu window air conditioner won't turn on, the fan is clean, the outlet is fine, fuse is fine. help!!!
mcdevito75 here, The switch on the unit could be bad, or the fan motor is bad, Check with your local A/C repair shop in your area.
Jun 23, 2010 | Heating & Cooling
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
Does not heat or cool
Hi, If the outdoor unit is running, make sure the fan is on also. If the system is new and has just been installed, it sounds like you may have a freon leak and have lost all its freon. Turn it on cool and let it run for a few minutes. Go outside and grab hold of the larger copper line coming out of the unit. It should be nice and cold and sweating. If not, and the fan and compressor are up and running, you have a leak and lost its charge. Check this and get back to me and let me know what you have found. We can go from there.
Shastalaker7
PS, When these installers put these units in, they sometimes get in a hurry and there welds are not very good and will leak over time, just to let you know.
Jan 26, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Just bought 12,000 BTU unit from Lowes. It worked
you have to balance the adjustment of fan speed and the amount of coolness you set the unit for. Either increase the fan speed or lower the coldness setting.
Jun 24, 2009 | Heating & Cooling
Haier Mechanical Air Conditioner HWF05XC7 Logo
351 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
