Those are Torques screws with the anti tamper pins. These screw drivers are available at most hardware and tool supply stores.
The "star shaped screws with a peg" in the center are called Torx security bits. They are not usually found in your local hardware store, but you can try. If not, look online for "torx security bits" you will find lots of places that sell them. I like MCM Electronics for those bits. However, you will also need a bit driver tool. It is like a screwdriver, but it has a magnetic hex recess at the end. Usually it comes with 4 bits already (2 flat and 2 crosspoint). The torx bits will also fit into it.
A for the fourth corner screw, you may have to remove the front control panel. I do not have your model microwave; I have a Jenn-Aire. After removing the trim, I had to gently pry the top of the panel down at the top to release it from the plastic catch. Then I could unplug the panel and get access to the two screws that the panel was hiding. Hope this helps.
Sometimes
the screws are tough, so you may only be able to just bend the post
slightly with a punch, then a small flat blade will "grab" enough to
turn the screw. Pliers on the handle will help, too.
Another
creative solution is to use a hacksaw or a Dremel tool to carefully cut
a slot in the head so a flat blade will fit it.
NOTE:
Always be sure to put any silver-colored cover screws back in the same
holes they came from. They are often used to ensure a good safety
ground from the cover to the chassis!
See these help files before proceeding:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
We're happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
