Question about Jandy Aqualink Rs4 One Touch Control System Control System
My aqualink rs4 controller in the house is powered off
Controller is off but can run pumps in maint mode
  • 139 Answers
Manual position over rides remote any remote
Posted on Jun 21, 2009
Freeze protection on when temperature is 80 degrees
Your air temperature sensor may be broken. Does the display show the correct current air temperature? You can go outside and put the system in service mode. That will shut the pump off. Then you can disconnect the air sensor and see if the pump acts right after putting it back into auto mode.
Mar 19, 2014 | Jandy Aqualink Rs4 One Touch Control...
The inside control display on my Aqualink RS4 is red instead of green on the filter pump button. What does this mean?
either the temp is below 38 degrees if so it is in freeze protect if not 38 degrees or lower bad temp sensor go to system set up and go to program go to freeze protect and un check the filter pump
Feb 16, 2013 | Jandy Aqualink Rs4 One Touch Control...
My aqualink rs4 display reads " service mode," how to I get it back to normal function?
This is set out at your equipment. It will be a button you push three times. It will have LED lights next to it. The first position will just run regular, the second is what you have now so you can control the system out at the equipment. Then the last is a three hour time out and will keep the system running as you left it in service mode. Your pool guy will use this to circulate chemical's after he leaves. I could be wrong but I think this is on the left side of your power center at the equipment.
Sep 27, 2010 | Jandy Aqualink Rs4 One Touch Control...
Jandy aqualink says Firmware Rev B11?
my pool power is on but the remote in the house does not work.
firmware rev b-11 is showing on the display and the display lights up.
what could be the problem?
Apr 11, 2010 | Jandy Aqualink Rs4 One Touch Control...
Spa does not turn off.
There SHOULD be a valve that you can close to disable the spa.
Sep 27, 2009 | Jandy Aqualink Rs4 One Touch Control...
Our aqualink rs4 is not turning on and we dont know how to fix it
Check the wiring. If you have nothing inside the house take the controller outside and hook it up at the outside controller
Jul 16, 2009 | Jandy Aqualink Rs4 One Touch Control...
SPA Filter on while Spa is Heating
If it has motorized valves the stop positions have to be adjusted so that the water coming back is equal to what it drains to stop the spill over process unless you want to add more valves but the pool pump does the job of heating and filtering the spa
Jul 04, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
302 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
jhalston
Level 1 Expert
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
