Question about Amana ALG643RB Gas Dryer
It ignites but does not heat hot enough to adequately dry clothes even though the gas is ignited. Doesn't appear to be hot enough. Amana ALG643RBW.
  • 530 Answers
Take the exsaust off the back of the dryer and run a load with it dettached and see if this makes a difference and let me know
Posted on Jun 21, 2009
It dries great and doesn't continue to run, however, on/off light still stays on even after it's done.
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Jan 25, 2016 | Amana NED7200TW Electric Dryer
How to fix a whirlpool gas dryer that tumbles but no heat ?
Air Flow and Heat
Warning
Apr 12, 2015 | Whirlpool Dryers
Gas dryer throws reset after a few minutes
Air Flow and Heat
Warning
Apr 07, 2015 | Dryers
Amana automatic dryer lga30aw won't push out gas and dry the clothes....any ideas?
Thermal Fuse
Air Flow and Heat
Warning
Mar 24, 2015 | Amana Dryers
Amana automatic dryer lga30aw won't push out gas everything else is working it just won't get hot.....any idea?
Thermal Fuse
Air Flow and Heat
Warning
Our propane kenmore dryer is not igniting. How do you fix it
GOD IS GOOD !!!!
Thermal Fuse
Air Flow and Heat
Warning
Oct 04, 2014 | Dryers
My kenmore gas dryer works for 5 minutes then control panel flashs and won't heat th cloths
GOD IS GOOD !!!!
Thermal Fuse
Air Flow and Heat
Warning
Sep 21, 2014 | Kenmore Sears Kenmore Clothes Dryer Flame...
Gas dryer
Thermal Fuse
Air Flow and Heat
Warning
Aug 18, 2014 | Jenn-Air Jenn Air Clothes Dryer LSG2700W,...
Model ALG643RBW Dryer heats sometime, APPEARS Flame Doesn't Always Ignite.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 22, 2010 | Amana ALG331RAW Gas Dryer
Amana ALG643RB Gas Dryer Logo
363 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
