Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1972 shovelhead engine needs spark plugs and oil!
I have a 72 shovelhead engine and I want to know what type of spark plugs can I use in it instead of harley davidson and also what would be the best oil to use in it instead of harley davidson also? About how many quarts would I put in it too? I think 4 but not sure. Thank you for your help!!
    Problem Solver:
  • 8 Answers
I have a 75 FLH and I use the Bosch Platinum WR8DP if you have the long plug if you have the short one it is W8AP, they are an exelent plug. As for the oil I use Rev-Tech grade 60 but you should stick with one kind of oil and for a FLH it is 4 qts.
Posted on Jun 27, 2009
  • 42 Answers
If it were me, I would only use Harley ... However, you could use Champion or NGK, they make good plugs. The biggest problem I come across is the nipple that the spark cap snaps on to is removable on most aftermarket plugs and they always come loose and can cause problems. As for oil, Any good ranked 50 or 60w air cooled engine oil could be used. Harley's oil is rated up to 360 deg. I would look for an equivalent and stray from using synthetic oils.
Posted on Aug 10, 2009
I own a 71 FLH and live in Florida. NKG plugs seem to work the best, the run hotter than most plugs, which is beneficial with low compression engines - 74ci. I also run octane booster and a little Marvel Mystery Oil to help with the lack of lead in newer fuels. As far as oil is concerned I have yet to find a better oil then Spector. I usually run the 60w in the summer due to the warm florida days, and 50w in the winter.
Hopefully this will help.
Posted on Aug 05, 2012
1972 Yamaha LT2 100 service manual
Hi, Rob originally the bike had only 1 spark plug with a spigot for a compression release valve or another spark plug, you need to check with your dealer about getting an ignition coil with dual plug wires for more information about your question and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1972 Yamaha LT2 LT2M Motorcycle Service Manual eBay $34
https://www.partsfish.com/page/oem-parts-for-yamaha
http://mybikemanuals.com/yamaha
72 73 LT2 LT3 Specifications
List of Yamaha motorcycles
Aug 06, 2018 | Yamaha Motorcycles
1972 Harley Davidson FLH 1200 no spark
Hi, Jzpaznthru and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Faulty run/off switch
11. Tilt sensor needs a reset.
12. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
77 Shovelhead turns over but no spark at plugs Harley Davidson Forums...
How to test your Harley Ignition Coil
https://www.carlsalter.com/pdfs/Harley-davidson-1970-78%20Electra%20super%20Service.pdf
http://www.harleyclasica.es/wp-content/uploads/manuales/1941-84-HD-FL-FLH-Parts-Catalog.pdf
https://www.carlsalter.com/pdfs/Harley_Davidson_FLH%20Electra%20Glide%201970%20Owners%20manual%20v2_2.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 15, 2018 | Harley Davidson Motorcycles
Need to find location for a 1972 mercedes 280 sel
I think the Bosch W230T30 were stock. new Bosch # is W5d1.
If you've updated the original plug wires to a non-resistor type, you may need a resistor type plug instead of the stock plug.
Oct 22, 2014 | Core New Core One Bullet Spark Plug...
How do i rebuild a 1972 shovelhead harley primary unit
To rebuild the primary of '72 Shovelhead is far too much to type out here. Besides, you'll need some pictures to help you identify a few things. You know the saying, "A picture is worth a thousand words". In this case, it's true. I'd suggest that you purchase a service manual. The best one that I've found is a Clymer's Manual, number M420 for Shovelhead 1966-1984. The factory manuals have been condensed so much that I think they rank second to this book. If you have a specific question, I can help there but to type out the entire process would be like me writing a book but without pictures.
Good Luck
Steve
May 14, 2011 | Harley Davidson SportClassic PaulSmart...
I have a 72 Yamaha LT2 100 what gear oil should i use?
20w40 motorcycle engine oil, the same as a four stroke motorcycle would use,
Not car engine oil as this can cause the clutch to slip.
Jun 06, 2010 | 1972 Yamaha DT 360
The bike is a 06 streetglide when you throttle the bike under load the oil pressure drops what would be the cause
I don't know too much about the oil pumps in the Twin Cam engines. I have never worked with one of them but I've got extensive experience with the older type pump used on the Shovelheads and Evolution engines.
A Harley engine employs a high volume low pressure oiling system. The old Shovelheads would actually show no oil pressure when idling hot with most gauges. The oil pressure switch would cut the light off at four pounds of oil pressure. A Harley engine will not hold a lot of oil pressure because the engine is built using roller bearings instead of shell bearings.
As long as the tappets are not rattling, you don't have a problem with oil pressure. If your oil pressure drops too low, the tappets are hydraulic and they will rattle like hell. There will be no doubt in your mind as to the problem.
Now, back to your question as to why the oil pressure on your bike drops when accelerating under a load, I have no idea.
Good Luck!
Steve
May 18, 2010 | 2008 Harley Davidson FLHX Street Glide
Whats the correct spark plug gap for a 1972 honda cl 100. And what is the recomended type of oil to use?
Correct spark plug gap is 0.6 -0.7mm and oil viscosity is variable like SAE 20/30w some thing like this and also depends on weather conditions.
May 13, 2010 | 1972 Honda CB 100
I just picked up a 72 350 that has been sitting
Change the oil, gasoline, and spark plugs. The carburetors will probably need to be rebuilt so be prepared for some leakage (fire extinguisher handy!). And of course don't ride it far on those old tires. Good luck, great find.
Jul 17, 2009 | 1972 Honda CB 350 F0
I have a 72 shovelhead engine and I want to know what type of spark plugs can I use in it instead of harley davidson and also what would be the best oil to use in it instead of harley davidson also? About...
try this for your plugs - might give a couple of options. maybe a later one will do?
http://www.harley-performance.com/harley-spark-plug.html
Amsoil 20w-50? Depends where you are and what you can get. I think there is a rev-tech oil to suit your shovel, but can't remember the spec off hand. Havoline 20w-50? Oil debates seem to rage on forever on most H-D forums around the world. Have found for me the H-D stuff is about the same price as the rest, and just as good/bad as them.
As for quantity, I'm thinking it is about 31/2 to 4 quarts, as you said.
Check these guys out - maybe better answers than mine mate. http://www.shovelhead.us/
Hope this helps you.
Jun 21, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
1,054 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
