Question about Sony Handycam DCR-HC28 Mini DV Digital Camcorder
Dcr-sr45 driver I could not find drivers
    Top Expert:
  • Sony Master
  • 76,060 Answers
SOURCE:
How do I fix "Inconsistencies found in Image Database File" REPAIR IMC. DB F.on DCR-SR45
Sir,
First of all you have to make the touch screen alive, then you can cure this matter easily with the camera, there is no way to fix it with computer, if you have a remote control of the same, it is helpful to do probably the cable comes from the mother board have some crack on it, so the touch panel will not work.
Jan 20, 2016 | Sony DCR-SR45 30GB Hard Drive Handycam...
Sony Handycam DCR-SR45 E:31.00 HARDDISK FORMAT ERROR
try connecting the camcorder to a pc using the cable, sometimes a pc can fix the drive. or you will need to do a factory reset. press in the rest button next to the lcd screen for 3 seconds.
Feb 10, 2018 | Sony DCR Video Cameras
My sony dcr-sr45 is only recording in black and white
it is most likely set in monotone mode in the menu... you can either set it back to normal or go to menu and reset back to factory .. either of these should work
Oct 23, 2012 | Sony DCR-SR45 30GB Hard Drive Handycam...
I need to find a LCD for my Sony Handycam. PLEASE HELP!!!
The Other LCD models are not fit to your camcorder.
If you want to buy a new one, you may use this link.
http://ebay.com
Write to the search box this nuber:320511486240
Press Enter.
Your LCD is this. If is suitable for you then you may buy it.
May 02, 2010 | Sony Handycam DCR-SR40 Camcorder
My LCD touchscreen on my DCR-SR45 fades to white
To resolve the issue,
Please open the LCD screen to locate the RESET button.
To reset the Camcorder, just press the RESET button using a sharp-pointed object.
Please make sure that the Camcorder is turned on while pressing the RESET button.
If the issue still persists, Power Reset the camcorder.
To reset the Camcorder, please remove the batterypack from the Camcorder and then set the Power Switch to ON for 15 seconds.
Then, reinsert the batterypack after 1 minute and check if that helps.
Mar 20, 2010 | Video Cameras
Touch screen does not work. How to replace.
it will only cost you 12.99
a month for my answer
Sep 05, 2009 | Sony Handycam® DCRSR45 HDD Camcorder
Cannot find drive
Download the latest drivers from sony..
heres a link, select your operating system
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRSR45&LOC=3
if that doesnt solve it, you may need to open device manager and check that your USB ports are working correctly
Aug 28, 2009 | Sony Handycam® DCRSR45 HDD Camcorder
Sony DCR SR 45
try to use ULEAD MOVIE MAKER its easy to use. if this application is compatible with your mac. you can edit it and saving it with high quality or anything that you like. burn it with nero application. hope that helps!
CHARCOIS
Aug 23, 2008 | Video Cameras
Sony Handycam DCR-HC28 Mini DV Digital Camcorder Logo
108 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
