Question about Meade LX200GPS Telescope
Power problem on my 10" LX200gps.
Where did you get the wiring schematic for the unit? I am an electronic technician and could troubleshoot the problem if I had a copy of the schematics.
Any help would be appreciated.
Thanks,
John
  • 3,186 Answers
Post this Question on the LX200 forum on Yahoo Groups-- many techs on the forum --
Posted on Jun 28, 2009
I own a GE Spacemaker microwave. The turntable & surface lights are not working. I have determined using a multimeter that neither the motor or the light fixtures are getting AC power (21vac) for the...
http://www.eserviceinfo.com/
if you cannot find the schematic you need, i'd suggest you unplug the unit and open it, fuses aren't that hard to find and replace. with your background, i believe you won't be having any difficulty.
Oct 08, 2013 | Microwave Ovens
My LX200gps 10 inch microfocuser has quit. Earlier my power button was intermittent, now it works. The handcontroller alllows you to slew, but not focus. I used spray contact cleaner in the power and...
When you plug in an outside power source the internal batteries are disconnected- automatically. First thing I would try is all new cables Sounds like the motor inside the focuser died.
Apr 12, 2011 | Meade LX200GPS Telescope
Hi do you know were i can get the electronics for the left fork arm or electrical schematics so i can make my own version. thanks steve
Contact the folks on the Yahoo LX200 group-- they have board pictures and knowledge of the electronics on LX200 scopes.
http://tech.groups.yahoo.com/group/LX200GPS/
Mar 17, 2011 | Meade LX200GPS-SMT 8 inch Telescope
I have a meade lx200gps 10" scope. The ra up is not responing. the down is working only. After initializing and fining north the auto star says stalled motor.
Do a calibrate motors and make sure you are using a separate 12 volt power pack or BRAND NEW internal batteries. All goto scopes work better with smooth, regulated power. The internal batteries will NOT work well for very long.
The Calibrate motors routine adjusts the motors for the power supply being used.
Oct 10, 2010 | Meade LX200GPS Telescope
Dayton Heater M/N 3E227E
Hard to believe they sell a retrofit kit for a Gas furnace to a Customer....This is ahrd to advise you on with out seeing the schematic and if it is indeed intended for that furnace....the Spark mounting location is CRITICAL for safety so make sure that is correct above all.....OK The wire coming off the transformer and tied to the red wire going to the heat excghanger would most likely be a High Limit switch...cuts the gas off if the blower doesnt work etc or you would have a fire...so this switch must be in series with the transformer to cut power when the switch opens....the wire MV/PV coming from the "Electronic control box" needs to go to the New Gas Valve you should have which will have a termional marked MV/PV (Main valve/Pilot/valve) as your old one was for a standing pilot application and when you have electronic ignition you req a Gas valve for Intermittent pilot .....you should also have 2 more terminals on the valve MV and PV which will have seperate lines from the ignition control as well....basicvally there will be another wire coming from MV/PV going back to the transformer...make sure all wiring is correct and I would strongly advise you have a technician check your work before you attempt to use it....if wired incorrectly you could have a serious delayed ignition as its possible to power the main burner instead of the pilot if you wire it up wrong below is a typical spark wiring diagram....may not apply totally to your system but it will give you the general idea79f9627.gif
Oct 31, 2009 | Heating & Cooling
Power problem on lx200gps telescope
If it's an electronic problem --- there are several folks on the Yahoo LX200 Group that can repair the board-- go there and ask for "RON"---
You should be using a stable 12 volt power source. The only other thing to check are
Get a temporary replacement for the hand controller and see if that works-- and-or get a low cost replacement hand controller cable from www.scopestuff.com and try the old controller with a new cable --- usually one of the capacitors is fried.
Jun 02, 2009 | Meade 10" LX200GPS Schmidt-Cassegrain...
Azimuth motor stalling missing the electronic home sensor
Check for binding in the gears; my 10" had aluminium chips in the fork base that jammed the gear. Cured by removing the RA manual adjust assembly - was useless anyway, as it could only be used with the RA unlocked. One setscrew in the fork base holds it in place,just loosen and pull up.
Apr 16, 2009 | Meade LX200GPS Telescope
10" Meade Fork, Quartz LX Pulse Drive
No schematics out there for that model, although there are ones for the LX classic and GPS. The center contact is positive.
Jul 24, 2008 | Meade LX200GPS Telescope
KLH ASW10-120B subwoofer
I realize that this is an old problem, but folks are still finding it on searches, so here goes.
Here are the two pages of schematics from KLH. I wrote to their tech department and explicitly asked for permission to share them here.
Here's the lower board, which has the power supply:
KLH ASW 10-120 subwoofer schematic - lower board
Here's the upper board:
KLH ASW 10-120 subwoofer schematic - upper board
Jan 25, 2008 | KLH ASW10-120 Subwoofer
Meade LX200GPS Telescope Logo
175 people viewed this question
Top Meade Optics Experts
Experi
Level 1 Expert
Joe Wright
Level 1 Expert
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Meade Optic Expert? Answer questions, earn points and help others
