Question about Canon PowerShot A540 Digital Camera
Shutters that cover lens not functioning properly.
I need to push shutters up to use camera,camera does work.
I have had the same problem, anytime I have been in an open field or at the beach or something like that. I believe a small piece of dirt or sand gets trapped in there somewhere and it can be an issue. Try giving it a good cleaning or blowing it out with something safe. It has happened to me 5 or 6 times over the course of 3 years and seems to work it's way out of it in a day or two if you clean it
Posted on Jun 26, 2009
    New Friend:
  • 70 Answers
I guess your camera is manual so that u have to push th eshutters do one thing take it to a repair shop they will repair it and it will be auto matic again.
Posted on Jun 21, 2009
Nikon S9500 Camera. The lens protection shutters do not open completely, but can be pushed open. Nothing seems to be stuck in the shutters.
A good lube for this is armor all. Wipe all the area or the shutters with a q tip that is dipped in it.
Oct 21, 2017 | Nikon Cameras
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Canon Powershot A510 - lens covers stuck
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it. There are many non-invasive techniques that people have come up with to accomplish this. Some may be seen on this blog article. You can also open the lens barrel up to fix the covers, but only as a very last resort. The article also gives examples for this type of procedure.
Jun 06, 2010 | Canon PowerShot A510 Digital Camera
The shutters on my Fujifilm E900 wont open or close properly.
Do you mean the lens cover on the end of the lens Is not opening properly, or the shutter inside the lens?
Aug 24, 2009 | Fuji FinePix E900 Zoom Digital Camera
Automatic lens cover won't open
Do you mean the shutters which protect the lens? If this is the case, are you able to carefully open them by hand? If so, there is a chance that a bit of dirt is preventing the shutters from opening. You might be able to get rid of the dirt by carefully sliding a bit of paper (I find yellow post-it notes perfect for this) in between the shutter and inside of the lens to shift the possible dirt. Also, you can try putting a minute drop of isopropyl alcohol (used in lens cleaning fluid) in between the shutters and the lens assembly so the possible dirt dissolves - then try to carefully open the shutters by hand. I don't recommend using any other alcohol/liquid for that.
Other than that, it's an absolute pain to get to the shutters to fix them properly on TZ3. Basically, the lens would need to be almost completely stripped-guide to do that would be beyond the scope of this site :)
Good luck,
Raf
Jun 08, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
SHUTTERS AREN'T FUNCTIONING PROPERLY
Repair costing close to half the price of new camera is uneconomical. And unfortunately if it is the shutter ( which seems questionable and sounds like the lens unit has sand inside and canon want to replace it ) you will not be able to do this yourself. Buy a new camera.
May 09, 2007 | Canon PowerShot A620 Digital Camera
Shutter Won't Open
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... The part number is: 178739811 Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 09, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Canon PowerShot A540 Digital Camera Logo
85 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
